Has anyone completed one of these yet on a Tool AA?
I need to find clear tailcaps to fit one. I don’t have mine in hand yet. Are they 12mm wide? How tall is the button, 5.5 or 7.5mm? It looks like KD did have some 12mm, but maybe not in clear :weary:
Could be possible, the internal size is around 16.3mm, the outer space is 15.4mm between the lanyard holes.
Only problem might be the cap squishing out if the retainer is tightened too much
Sooo, the bleeder resistor thing plus the tailcap resistor(s) is the path which powers the tailcap leds. For 2x blue leds with 330Ω resistors each, which is 165Ω average, what do you think is a reasonable bleeder resistor? I say this because looks like some of you use a much higher value bleeder resistor than what pilotdog68 suggests in the opening post. This of course is to reduce tailcap leds' current draw but, how much is too much? I think I'll try 2 - 3KΩ at first, hope the tailcap can still be seen reasonably with that. ♪~ ᕕ(ᐛ)ᕗ
It also depends very much on the driver, on some drivers it will never work without messing up the switching timings, but I often use 680 Ohm bleeder and a few thousand Ohm in series with the tail leds, it sounds like your 330Ohm is very low.
The tail resistors also depends on if you’re using a ring-style board or the older style with the LEDs mounted on the switch board. Based on your 2 LEDs and each with a resistor, I’m guessing it’s the switch board style. Even still, that resistance sounds low. For a 2 channel blue ring board, I would usually use ~14,000 ohm resistors. Not sure about the older style.
My go-to bleeder is a 750 Ohm on nanjg105c drivers. For drivers using an OTC, it really varies as djozz said. I’ve used 220 and I’ve used 1200 (and still not had great results with some!)
Mmm, for an H1-A I will have to try and see what happens:
I think it should work no problem, but of course I cannot say for sure. :-D
Is OTC = On Time Capacitor? The H1-A memorizes used mode after ≈2S, but as far as I can see in the above diagram the bleeder resistor shouldn't mess with this stuff. Am I right if I say C14 and C13 are the MCU power timing capacitors? (^̮^) Well, of course I have not analyzed how it really behaves but looks like that.
Well, I meant an Off-Time Capacitor like you’d see on the BLF A6 or X6 drivers. For drivers with on-time memory, I’ve had good luck and they haven’t been very picky about the bleeder value. Some of them actually work ok without a bleeder, though very little current can pass thru - a bleeder might help brighten up the tailcap. I’d try something like an 840 Ohm perhaps for an on-time driver. Just my 2 cents… I could be way off base.
Quick tip for bleeders on the nanjg105c-style drivers: I picked up some 1206-sized resistors (from here) and they fit nicely between star1 and the spring. No bridging or stretching needed. And much easier than trying to arrange an 0805 between the 7135 and the spring.
PS - if you haven’t seen them yet, I’ve whipped up some simple constant-brightness tailcaps with LVP built in. Post here.
There’s a bit more detail in the post linked above, but in essence… It uses an MCU to take periodic voltage readings (using internal VREF) and set the 8 LEDs which are on separate I/O channels. It goes to sleep and periodically wakes up to take another reading.
Nice but, as it is, I think it lacks continuity. I mean, the amount of lighted leds versus voltage is way off. Taking a look at some typical cell discharge curves (Batteries & Chargers @ lygte-info.dk) can help with the voltage steps for a better capacity/energy to amount of lighted leds mapping.
P.S.: if the animation somehow gets in the way of practical usage, I'd remove it.
