Sofirn SP70 Alone $50, PM for AMZ US CODE(LIMITED)
I like it Jason. :+1:
That’s also what I deciphered… SP models have side switch, while SF are only tail-switch.
Some SP models have both side & tail switch (eg. SP30A, SP31).
Sofirn has an official website, but it doesn’t seem to be that well known (a Google search for “Sofirn” will more likely than not link first to their Sofirn AliExpress Store rather than the “official” Sofirn website).
http://www.sofirnlight.com/en/product/productlist
There are more series listed in the Sofirn product list (SP, SF, SD, etc). Thorfire’s “TK” series is also on the list, although no models are listed there yet (many of the other series also don’t have any models yet, apart from the well populated SP and SF series).
Jason:
Like the levels :wink:
About turbo:
If unlimited fet driven madness like with a TA driver heat is an issue. But I played with the MF02 XHP70.2 yesterday and from 4000 to 9000 lumen the output bump with naked eye is not much but with 4k it can handle the power without heating up for 10 minutes. But with 9k it gets hot about one and a half minute. I’m trying to say that 6-7k lumens is about enough for turbo because above that most power will be turn in to heat and not light. For real world use it is better longer turbo runs without much heat.
Thanks for the Sofirn website link d_t_a!! I did not know they had one… :wink:
I only knew about the Amazon & AliExpress stores.
Here is a rough concept drawing. It’s is somewhat based on the L6 as I like that shape more than the S70.
You can have the same external appearance with both a single emitter and a triple emitter. With the triple emitter you get much more mass under the shelf, plus deeper fins. It’s a win win. :smiley:
Note that I used the L6 75mm head diameter by mistake. The 90mm SP70 will be bigger in relation to the battery tube.
Also note that I’m a skilled photoshop user, but I only had paper and my phone for the above.
I don’t know if memory limits the number of modes or not, but if I had to sacrifice a mode I’d say the moonlight would be the least useful for this style of light. If we can keep it, great, but I think it might be more useful to have an additional “High” mode that can still be usable for a while. Something like:
  • 1-2 Moonlight (If possible)
  • 40-50 Low
  • 250-300 Med 1
  • 800-1000 Med 2
  • 2000-2500 High
  • 3500-4000 Highest
  • 5000+ Turbo
Double-click to Turbo sounds good to me too.
(I also would still like to save a little bit of memory space for a hidden strobe and at least one beacon too, as discussed earlier in this thread.)
Hmmmm…… What sb says makes a lot of sense. And if moonlight was lost it would not be a great loss on this light.
I would like to see much thicker walls behind the fins.
The fins on the right side will be virtually useless as there is no path for the heat to travel.
Same for the upper fins on the left side.
You want the body of the light to hug the reflector outline as close as possible and make the fin depth such that you give the heat a good path to move up.
Note that my L6 with fully charged Liitokala’s typically does about 6000 lumen (P2 1A bin, 17A at tail). Since I use it at my work I have to be a bit more practical with it so I usually ramp it down just a little from max. This is like the 80% ramp we have in the GT. In my case it tends to be about 2500 lumen. I think that making it a bit higher would be okay. We just need to try it first hand.
If the prototype SP70 can do 9000 lumen, then that would be great, but I don’t think it will. It may end up around the 6k to 7k range. If it can handle 4000 lumen for 10 minutes then I would be fine with that. It’s a matter of finding that sweet spot where the output only seems to drop a little, but the amp draw drops a lot. I know what you mean. Plus I only know the L6’s mass and heat characteristics. The SP70 might be quite a bit different.
So maybe:
1-2 Moonlight
40-50 Low
250-300 Med 1
800-1000 Med 2
2500-4000 High (whatever is practical)
5000+ Turbo
Worse case scenario, set your own “High” level in ramping mode. :smiley:
I think beefing it up as the red area above suggests is important. It should be easy to do… so let’s try to do it. :+1:
I like the proposed levels as well, covers every practical use I would think, with sensible intuitive spacing. The high level should be determined by sustainability though, not predetermined. Turbo of course should be at or close to maximum achievable for a 1 to 3 minute burst.
I really like the 3 emitter design with deep heat sinking, would do for this form factor what the C8F did for the C8. If I recall correctly previous discussions on fins and spacing the hand drawn fins are maybe too close?
:+1: Anywhere in that ballpark would be incredible for a midrange thrower like this, and would really put it in another league.
Nice! Sounds good.
It’s not a cad drawing! Lol
I just wanted to show the shelf idea and I had to do it quickly. Feel free to tweak it or do your own drawing.
4-5000 lumens high is too much I think. MF02 has much more head mass. And the jump from that to 6-7000 is not significant. 3000-3500 lumens ramp max can run until battery dies with slight warming up.
OMG this is so important especially for a sustainable high output light like this! :+1: I don’t want a 7000lumen light that loses 2,000 lumens in 1 minutes
lol, I am aware but for some reason the china manufactures love to make the walls that thin unless we specifically tell them to make them thicker.
Basically they should leave as much material as possible inside the head, there is really no reason to remove it, the slight weight savings is not worth it IMHO.
Looking good. I like the levels as well. And agree with thicker walls. Thanks to all putting work into this. :slight_smile:
Sorry if this idea has been addressed.
we have “shorty” versions of small lights. How about a “shorty” (2 cell) version of this with a 1 tube if folks want to run 3 cells
Do you mean shorty 26350 2 Cell tube? I’d be in for a one piece 3 Cell 26650 tube for sure.
It already stated as a 2 cell version. a 2/3 cell driver will raise the driver cost. If somebody need more runtime carry 2 extra battery and problem solved with even more runtime than 3 battery.
