SSC p7 D-bin
4 posts / 0 new
xP.1337
Last seen: 7 months 4 weeks ago
SSC p7 D-bin
need one on a 20mm star.  i must be blind cause i could have sworn ive seen these online before!
all i found was 21mm on KD
now on other leds i would dremel down the edges HOWEVER
the p7 lense catches ALL that sandings and you CANT clean it, so i need one premounted.....
see if we have better luck with this since i got no info on the MC-E questions earlier
FlashPilot
FlashPilot's picture
Last seen: 2 hours 10 min ago
Take a piece of making tape large enough to cover the PCB. Take a piece of plastic wrap and cut out a small circle about the size of the emitter with scissors. Place the plastic circle in the middle of the sticky side of the tape. Align the plastic over the emitter and stick the tape to the PCB. Trim with a razor to the outside of the PCB before you dremel. When finished grinding, peel off the tape. Done!
xP.1337
not a bad idea
thanks for the tip.
still gonna spend some time looking first tho
agenthex
agenthex's picture
Last seen: 7 years 11 months ago
If you use mild tape, you don't really need anything else. Also, 21mm may or may not mean "I made a mistake measuring 20mm".
Reading this makes you smarter: http://lesswrong.com/
