Do you think a MTN Quad XP, carclo optic and glass can fit in there? I want to build a medium power EDC with solid permanent clip and this one looks perfect.
It is your lucky day! The diameter of the Carclo quad is a perfect fit, but in the postion of the picture the legs sit on top of the board instead of in holes, so in a quad build it will sit a bit deeper (which is way better than if it sat too high ). To get the height correct, under the ledboard a spacer (1.5mm?) is needed, I say an old 20mm ledboard with the circuitry sanded off.
The new toy will at least feature in a new luxmeter comparison (it also has luxmeter function), and in various little tests. But it is mainly for own experimentation and fun. It is a little Mavolux Base spectrometer and I forbid everyone to look up the price because it is pretty idiotic that I got myself one :person_facepalming:
(will postpone financial support of family for the next two years )
djozz, can you please tell if the driver is 20mm? Is it press fit or maybe glued?
Also, when you say that a spacer would be needed to fit the optics, you mean that to raise the MCPCB, right? Even with that āraisingā, would there be space for a glass lens (above the optic)?
Thank you in advance! Iām still on the line to buy this or not, to mod itā¦ :person_facepalming:
In the picture the optic sits flush with the head and would look the same after using a spacer under the MCPCB, so the glass would go on top of that. I normally donāt use glass on top of optics but it always depends on the waterproofing design, anyways this light looks very promising for modding and since it has a tail switch I donāt think the driver should be a problem. I think the pic of the driver in the OP is 17mm, glued on the other side maybe?
Yes, if you make the optic sit where it is in the picture, a glass lens (1.8x25mm, 2mm thick will work too) fits on top of it in place of the stock plastic lens.
The driver is 21.6 mm diameter, dunno if it is press-fit or glued but donāt worry, you will get it out.
djozz, many thanks on this information
About the driver, their AX1 has the driver glued, a bit harder for me to put it back in place, thats why I asked. On the other hand, their VG10 model has a press fit driver, easier to remove and replace. Oh well, guess Iāll have to find out which one is this afterall :smiling_imp:
No, it does not do that. The specs say up to 6kHz but to be honest, at first glance I canāt interpret the numbers very well, have dive into that some time. And build up the lightsensor-handscope circuit (as described in Terry Oregonās thread) to check it against.
I did check the spectra it produces with a helium lamp though, perhaps nice to see, the peaks are dead-on the nanometer (which I think is the most important parameter for the numbers it calculates to be correct), but the wavelength resolution is not as high as I would like to see (of course).
Pic from the internet with peak wavelengths:
The heliumlamp that I measured behind a slit and photographed through a diffraction grating (my phone camera appears to not pick up light over 670nm):
Now youāll have to download the IES TM-30-15 Excel calculator for deriving the new color rendering info from the spectra. Or does the Mavospec have the software for TM-30-15 calculation already?
