Many of the features desired by some members, and perhaps a small subset in some cases, drive up the price of the lantern. Although it may only be a dollar here or there they all add up and could perhaps raise the lantern price by upwards of 25% (just a swag here :money_mouth_face: ). The design has progressed from a fairly simple lantern to one that has many nice-to-have features but are they all needed or will even be used by the majority of people?
Just thinking out-loud so take it strictly as that :confounded:
What features are you speaking of?
USB power bank is the only one that could add costs because of additional parts; tint adjustment is mostly a firmware thing (aside from one additional wire, as I understand it); are there others?
As I said I was just thinking out-loud about things :partying_face: . But the powerbank feature is one that I wonder how many people will really make use of. I could easily be wrong of course and perhaps many people will make use of it. Iām an urban guy and donāt go backpacking or usually venture to places where Iām away from power so my take on things are clearly one-sided. Usb-c is another additional cost but admittedly small (well a few bucks more for me because I need to buy cables). In mulling things over perhaps the incremental costs are much smaller than I estimated as that was as I said a swag.
In any event Iām confident that the lantern will be an awesome thing and am excited that itās progressing so well. One is going into my earthquake supplies where hopefully it will never be used.
Many thanks to everyone who have contributed so much time and effort on the lantern :+1:
The user name list often as the last few entries not sorted in, so if you donāt find your name in alphabetical order just look at the end of the list.
I would absolutely use the power bank feature, as would anyone I knew thatās using it outdoors. We use our phones for GPS navigation, music, cameras, etc and always have a power brick with us. This lantern will have plenty of capacity to serve as a battery brick so I certainly vote for it.
That said, itās not needed if itās a deal breaker and I am much more concerned with the lanternās durability/reliability and function than itās use for power.
I think the power bank function will not cost more than 5 bucks, ie. equal to or less than 10 percent of the cost of the device.
It is acceptable to me ā¦
Yes, it should have a built in charger, USB micro or C input, preferably with MPPT type conditioning so that it can be connected to anything from a small solar panel to a high power 2 or 3A connection.
After that, I see it as optional. Those who want to then use it as a power bank could take out some or all cells and put them into a lightweight inexpensive powerbank housing to charge up their mobile or tablet etc, or put into a more suitable lightweight torch for backpacking.
Whilst charging up another set of cells at the same time. I.e. four cells total could keep this setup working fully, 2 charging in the lantern, 2 in use elsewhere. Or all 4 to keep the lantern going for a week or so. Or two sets of four, and a big solar panel.
More flexible than having the powerbank circuit built into this heavy lantern.
But if the powerbank output can be done at minimal cost, complexity and development risk, by all means go for it.
To me, the powerbank output only makes sense in combination with solar input, for those who want to run totally āoff gridā or survivalist, but a decent portable panel will cost as much as this torch. I donāt see too many making much use of this. Just plug it into the car, or the mains, or take a spare set of cells.
If the cells are not going to be charged by solar in a minimalist arrangement (lantern + solar panel) then whatās the point ? If vehicle or mains power, or solar (not directly connected, my campervan has 200 W of solar) is to be the source then easier to use a separate charger.
TBH, a straightforward lantern with no charging or powerbank circuits would suit me better, at the right price. If it could also accept primary cells (e.g. alkaline AA etc. in a carrier, 3S or 4S), even better.
Much as I like the idea of spending weeks or months in the wilderness, off grid, not even a motor vehicle to charge from, itās never going to happen for me, and when I do wander off for a week or two, I donāt take a heavy lantern. Or anything powered only by Liion.
We donāt need MPPT functionality here with such a small power pack. We just need to use a CC/CV buck converter instead to charge the lantern limited to say 2A. We donāt need the efficiency improvements of an MPPT buck boost controller, which will add to the complexity of the lantern considerably.
Also, I do not think we should go with AA sized cells. Alkaline cells, being left long times in the lantern, could easily leak and ruin the lantern. It would also lower energy density, and introduce the fact that series arrangement carry a risk in a lantern that does not need it.
Staying with lithium ion in parallel will also grant one massive advantage: being able to run with a single 18650 cell. It doesnāt matter if you run it with 1x18650, or with 4x18650 in a lantern, as it just changes runtime.
Using AA sized cells in series would mean you have to use 3-4 cells at a time. What happened if you only had one on hand, or even just two?
