Need help please. I can't figure out how to post a picture (have read the turorial and tried from Imgur, Flickr and Google Drive). Can anyone post my design of the BLF L1 lantern logo found here: https://imgur.com/a/YSC4Uzr
I may be wrong but I think this is ābasicallyā what DBSAR decided onā¦ā¦ I imagine he will probably do some tweaking before it is sent to the manufacturer. (i.e.- font, ray spacing, etc) I do like your font better thoā¦ā¦
As for the logo, a design will be set in stone soon for the manufacturer, as i already sent Barry a high res drawing of the logo i posted earlier. We can play with designs, drawings, and ideas for a logo for centuries, but have to set a time limit and a pin down a design. Not everyone will like the same one, but we canāt spend to much time & effort in a logo that āeveryoneā likes perfectly. The more important things are getting the actual lantern rolling with the manufacturer. I have provided Barry with all the design drawings & specs for the BLF lantern, and awaiting to hear back from Barry & them as he said their engineers are working on the design to produce a prototype sample.
The problem with getting into the habit of this is that it may, depending who is with you, lead to someone thinking it is a bright idea to take a cell or two they have now fully depleted in a separate powerbank, and put them back in the lantern, in parallel with 2 or 3 fully charged cells, leading to potential disaster.
That is far less likely to happen if availability of a powerbank function gives them less reason to take out a cell.
On the other hand, this cell imbalance potential makes it advisable for someone who is planning a long trip to take a 4 bay powerbank with independent charging bays as well, both to balance cells before inserting a set in the lantern, and to hold a backup set of cells.
Iāve heard this tale of woe and disaster enough times now to actually try it. It just doesnāt happen. New Samsung 30Qs, one at 2.7V, the other at 4.2. Paralleled directly, almost zero resistance.
Nothing bad happened, temperatures remained safe, energy was transferred, perhaps not very efficiently
Try it yourself, maybe put it on youtube. We donāt seem to get so many (suspect) videos of exploding Liions these days.
You can put four cells of varying chemistry and state of charge into e.g. a Q8, and after a few hours they will have balanced voltage perfectly (couldnāt do otherwise). These things really arenāt such precious fickle technology as some think.
I have to say I agree with Tom Tom here. :innocent:
Iād almost bet money (if I had any) that you couldnāt make a modern Lithium cell from one of the top quality brands explode or leak if you tried, short of physically abusing or pumping a lot more energy into them from some heavily powered source. A friend of mine put a cell in backwards in a modded SRK-style light we were using. The light was like that for a couple minutes before I even realized it. I had a real scare, but nothing exciting actually happened. So, I took the cells out of the light and put them back in my four-slot charger, since they had all run down trying to reverse charge each other! Okay, they were a little bit warm, but no more than they usually are from running continuously on high mode.
EDIT: Oh yeah, these werenāt new cells either. Theyāre all pulls from defunct laptop batteries.
Iām surprised that 30qs didnāt get hot doing this, but what about if there was spring wire between them instead of zero resistance? I would expect 1.5v at those currents to do some damage, I remember how hot wire would instantly get when I accidentally shorted low capacity NiCads a few decades ago.
Now that i have made it home after my month-long trip, The tests of the prototype went well. I lost count of the people who asked ā where they could buy oneā and i said they are not commercially available yet, but told them about the project and took a list of names of them for when it comes available, directing them to here on BLF.
Been following this for a while and it looks great! Iād like to get on the list for 2.
I was also wondering about future availability of the lanterns. Is this going to be a one time option to purchase these or will there be stock available if we wanted to buy additional lights a year down the road? Iām asking because Iād like to test these out when available then look at replacing 5-6 Coleman propane lanterns for our Cub Scouts camping gear.
Thanks for the work you all have been putting into this!
