http://www.jayki.com/11145 Posted the test for this cell ... on Jayki ...
The link is not working
Jayki is down - for a rebuild
Do you recall what they said about those cells? Good or Bad?
I've not tested one of these, though I have seen others that have, and if I remember correctly, these are much like Ultrafire 3000mAh cells,
There's an outside chance that you'll get a reasonably decent cell, but rather a high chance that you'll get any old cell with a colourful new wrap slapped over it. You'll not get 3000mAh capacity. Just how low a capacity you get will depend on what cell is under the wrapper.
I'll stick to the Trustfire Flames then. I have had good luck with them so far..Thanks
Bad - dangerous - keep away - look elsewhere for a 18650 , along those lines [ what I said ]
Confirmed - not good quality.
