Still waiting on boards for the rook driver but in the mean time I decided to find a way to put BLF-A6 FW on some more old lights and what do you know, cut one trace, solder one bodge wire and you’re G2G!
I got my 351ds in today, and had time to finish up my Manta Ray quad build. In my rush I didn’t notice the mcpcb was off center a tad bit and it’s eventually going to bother me so I will center it again when I have time. Here’s some pics:
The other week I cut the back end of the body on my swm and threaded on a new blank tail piece. Today I fitted a pocket clip. I didn’t thread the Ti for the screws as I feared breaking the tap off in the hole, so it there is a couple of small nuts on the other side. Have more planned… slowly slowly…
H17F modded to run 2 individually addressable leds.
The H17F has 24 brightness levels across all 3 channels as follows,
Step 1-15 PWM, 16 (constant). Channel 1(single amc7135) Active.
Step 17-21 PWM, 22 (constant) both CH 1 & 2(all 8 amc7135) Active.
Step 23 PWM, step 24 (constant) all amc7135 & FET Active.
So the mod is to remove the FET and install an additional amc7135 for the colored leds on channel 3… but the problem is that when channel 3 is active… channel 1 & 2 are also on, so the solution was to wire CH 1 & 2 signals thru 2 P mosfets separately, I cutoff the signal traces off the PCB as shown in the 1st picture, than I wired them from the MCU to the source pin of the P mosfets, from the p mosfets drain to the gates of CH1 & 2 amc7135 bank. Than I wired CH3 signal to the gates of both P mosfets & the gate of the additional amc7135 allocated to the colored leds, only problem is step 23 which is PWM driven not cabaple of fully shutting down both P mosfets even when tried using a low pass filter
Will be used for a triple build with 3 white + 3 colored xq-e
Steps 1-22 are normal modes white light, step 23 is both white and colored combined & step 24 is just the colored led.
I got a new toy, I got a new toy!
My machined finish Convoy L2 is now making 2553 lumens from an XHP-35 E4 5700K HD emitter. Lovin it!
Edit: Oh, yeah, from a single 26650.
It pulled 2.08-2.15A at the emitter for 3 minutes, pulling the Shockli 26650 down from a fresh charge to 4.09V. Ran from 8.6 lumens to 2553 lumens, so while I loved the machined finish L2 before, now it’s just POIFECK! :heart_eyes:
What boost driver did I just kill, you mean? :person_facepalming:
I, uh, seem to have gotten ahold of some old instructions and made a bridge where no bridge was designed to be. Ooops! Maybe I can hot air reflow a component and bring it back to life, checking…
Uh-oh. 3A in a plastic-body light? That poor LED’s gonna get heat-stroke in about a minute with nothing to wick away the heat.
I got a coupla NexTorch nylon-body lights, which come with a 1W LED drop-in, so that’s probably 350mA tops. I wouldn’t push a revamped module past 2W or so, and that only in “burst mode” (ie, get it over with quickly so the LED doesn’t burst).
@Lightbringer
Thanks for your concern, I thought about it too.
I found that the head is actually made from aluminium so hopefully it helps dissipate the heat. Although I also found that drop-in has more contact to the body than to its head. I also made precaution not to use this flashlight intensively (always carry several others for backups).
I forgot who pointed me (and blf in general) at the NexTorches, but he mentioned that it’s nice for camping, etc., when you’d want something that wouldn’t be cold metal in your hand in the middle of winter, etc., so I figured why not? And also to maybe keep one in the car or something and not have it wear off the ano by bouncing around. Just enough light to be useful changing a tire, poking around underneath things, etc.
But I left a 2.8A S2+ tailstanding for just a few minutes on high, and it pretty much turned into a curling iron. I grabbed’n’dropped it so fast, and couldn’t even turn it off! Had to grab a shirt or whatever (been a while) just to grab hold of one end so I could bap the switch off on the other, and even after air-cooling a few minutes, it still was too hot to pick up, even two-fingers on the tailswitch, farthest away from the LED.
And that’s a pretty solid tube wicking away heat and spreading it around. So when I saw you were using a 3A driver in a drop-in in a plastic-tube light… well, I could visualise the plastic light melting like a Dali painting.
