Yes
H17F modded to run 2 individually addressable leds.
The H17F has 24 brightness levels across all 3 channels as follows,
Step 1-15 PWM, 16 (constant). Channel 1(single amc7135) Active.
Step 17-21 PWM, 22 (constant) both CH 1 & 2(all 8 amc7135) Active.
Step 23 PWM, step 24 (constant) all amc7135 & FET Active.
So the mod is to remove the FET and install an additional amc7135 for the colored leds on channel 3ā¦ but the problem is that when channel 3 is activeā¦ channel 1 & 2 are also on, so the solution was to wire CH 1 & 2 signals thru 2 P mosfets separately, I cutoff the signal traces off the PCB as shown in the 1st picture, than I wired them from the MCU to the source pin of the P mosfets, from the p mosfets drain to the gates of CH1 & 2 amc7135 bank. Than I wired CH3 signal to the gates of both P mosfets & the gate of the additional amc7135 allocated to the colored leds, only problem is step 23 which is PWM driven not cabaple of fully shutting down both P mosfets even when tried using a low pass filter
Will be used for a triple build with 3 white + 3 colored xq-e
Steps 1-22 are normal modes white light, step 23 is both white and colored combined & step 24 is just the colored led.
Love your work pp.
Fady, I always liked a bit of black magic.
MRsDNF, I updated my post to explain it a little better.
I got a new toy, I got a new toy!
My machined finish Convoy L2 is now making 2553 lumens from an XHP-35 E4 5700K HD emitter. Lovin it!
Edit: Oh, yeah, from a single 26650.
It pulled 2.08-2.15A at the emitter for 3 minutes, pulling the Shockli 26650 down from a fresh charge to 4.09V. Ran from 8.6 lumens to 2553 lumens, so while I loved the machined finish L2 before, now itās just POIFECK! :heart_eyes:
Ok spill the beans. What boost driver are you testing??
What boost driver did I just kill, you mean? :person_facepalming:
I, uh, seem to have gotten ahold of some old instructions and made a bridge where no bridge was designed to be. Ooops! Maybe I can hot air reflow a component and bring it back to life, checkingā¦
Yesterday I build a p60 drop-in for Surefire G2 (nitrolon) to replace its built-in engine which has only 120 lumens output.
Got materials from Fasttech:
- Cree XP-L V5-2A 1186.05LM 5700-6000K LED Emitter
Sorry I donāt have the WIP photos but here are the results.
I do like the tint of this emitter, I call it āpure whiteā.
Uh-oh. 3A in a plastic-body light? That poor LEDās gonna get heat-stroke in about a minute with nothing to wick away the heat.
I got a coupla NexTorch nylon-body lights, which come with a 1W LED drop-in, so thatās probably 350mA tops. I wouldnāt push a revamped module past 2W or so, and that only in āburst modeā (ie, get it over with quickly so the LED doesnāt burst).
Not to be Mr Glass Half-Empty, butā¦
@Lightbringer
Thanks for your concern, I thought about it too.
I found that the head is actually made from aluminium so hopefully it helps dissipate the heat. Although I also found that drop-in has more contact to the body than to its head. I also made precaution not to use this flashlight intensively (always carry several others for backups).
Kewl, umm, so to speak. ;D
I forgot who pointed me (and blf in general) at the NexTorches, but he mentioned that itās nice for camping, etc., when youād want something that wouldnāt be cold metal in your hand in the middle of winter, etc., so I figured why not? And also to maybe keep one in the car or something and not have it wear off the ano by bouncing around. Just enough light to be useful changing a tire, poking around underneath things, etc.
But I left a 2.8A S2+ tailstanding for just a few minutes on high, and it pretty much turned into a curling iron. I grabbedānādropped it so fast, and couldnāt even turn it off! Had to grab a shirt or whatever (been a while) just to grab hold of one end so I could bap the switch off on the other, and even after air-cooling a few minutes, it still was too hot to pick up, even two-fingers on the tailswitch, farthest away from the LED.
And thatās a pretty solid tube wicking away heat and spreading it around. So when I saw you were using a 3A driver in a drop-in in a plastic-tube lightā¦ well, I could visualise the plastic light melting like a Dali painting.
I can see Daliās painting is aesthetic but not for a melting plastic from a flashlight :person_facepalming:
I made a full round battery tube for my Quad M1 yesterdayā¦.āThe GRATERā :heart_eyes:
EDC Tipā¦. Lightly shred some Romano cheese for your Chef Boyardee MEAT Ravioliās when in the field!
(Love them bad boyās straight out of the can) :+1:
Nice job Kawi, that looks great!
Could it be bored out to 20700 since itās full round?
2x20700 + xhp70.2?
My 2x 18350 M1 is drooling just thinking about it.
Thanks V77! Looks better in person, when the light/sun hits those diamonds at a certain angle, wow! I cut the o-ring grooves today and put a slight polish to it too. I got a 26650 and a 32650 tubes Iām doing next. When I get the time, I did this in 1hr 15 minutes, so 2 1/2 hr. lunch breaks and a 15 minute morning break, I used the old lathe at work.
Yeah, I tried to make it for a 21700, I should of gone 20700, it might have worked. But seeing I had 2-30Tās I had to try. I actually cut the thread, but it was Tin Foil thick. The M1 is the biggest tube/head diameter wise I have come across for a 18650 light, I gave it a shot, but failed, well in that aspect! I might try the 20700, I have plenty of stock just not the timeā¦ā¦ yet!
I love your grater. That is some really nice machining.
Hey Steve, coming from one of the best Tool Makers I have seen in a long time, thatās a heck of a compliment! Thank you very much!
Iām wanting to get back into it, tired of building CNCās and Special machines, I really love turning handles, so for now small, simple and quick mech/mods keep me some what sane.
Somewhat? :person_facepalming:
