(prototype) the GT Mini
I think your confused. I did not mention anything about the big GT or its manual.
I also don’t see any errors in my response as it’s straight from the GT manual.
UPDATE TO MANUAL
After trying mode 4 and mode 10 it appears that the groups are reversed.
Modes 1-6 use full turbo as 100% (5A)
Modes 7-12 use the top of the ramp as 100% (2.5A)
We definitely need an updated manual to reflect this.
Edit: And here it is.
GT Mini User Manaual
What problem did you have?
I am lost… you said mode 7-12 use full turbo… you also said mode 1-6 use full turbo… whats that??
I’m not saying either. I’ll edit my older post.
At first I went by the online manual for the GT Mini, but it was incorrect. Then I tried out both modes 4 and 10 on my light and found mode 4 used 5A and mode 10 used 2.5A. So something was fishy.
Then TA pointed me to the latest updated manual (v5) and it shows a whole new unique set of mode sets not seen in previous versions of NarsilM v1.2
You can use the link I posted to see the levels.
Is the Aspire cell new? Is that result repeatable?
So far I haven’t seen any evidence of the existence of another cell that would compete with Yong Deli (used by Aspire) when it comes to both capacity and internal resistance.
Now that Shockli actually seems to be something different…but I’m not yet convinced.
Also, the Shockli stated capacity is about what would I expect them to state if they used the YongDeli.
is that correct?
Where did this come from?
was posted to Neals facebook
I guess you would need to have a ROT66 to confirm its accuracy.
Some things I notice is that it says you can press and hold to get into the menu. They might have used 16 seconds in ramping, but it’s always best to ramp down to get into the menu. If your in mode sets it only takes about 3 seconds.
Of course, if you are in mode sets the menu is different. So maybe the diagram should be labeled (only in ramping mode) under the “16 seconds”.
There’s no mention of the mode sets menu or all the mode sets brightness level options (1-12). I guess this was on purpose to keep things simple.
Im in the US. Mine says the same…but shipped on the 3rd.
Yep… mine says 3rd too. :smiley: . Looks like they are all just sitting around waiting to leave.
Note to self….Maybe I won’t use EMS ePacket China again, given a choice that is. :smiley: . :wink:
Mine just got updated from ‘processed through facility’ to ‘shipped’.
US order w/out batteries.
That blows…im sure we will get this or next week…i HOPE this week.
Yep…. it does. I agree, end of this week or more likely next. :wink:
Look closely at the day & time of the last two 17Track entries for my order. :person_facepalming:
It appears someone is confused…… :smiley: :smiley: :smiley:
2018-08-03 22:46
Guangzhou, leave Guangzhou send to Guangzhou courier company
2018-08-03 22:46
Guangzhou, leave Guangzhou and send to JFK Airport in New York.
BG say they tried to shipped it out within one week… i got this info from banggood facebook.
M4DM4X
is this diagramm for the GTmini or ROT66?
- describes only RAMPING no MODES
- everything starts from OFF. But you have also access to everything when the lamp is ON
  • can be difficult to read when printed in black and white?
- Not everything is in the diagram. I think it needs some text to explain it to a NarsilM beginner.
I actually thought I was in the ROT66 thread when I mentioned it earlier. I edited it out.
I’m guessing that diagram is for the GT Mini.
not sure - I was thinking it's for the GT Mini
also I belive 90% of the narsil users will find more information than needed and for playing with the new light once to set it up its ma be a good way to visualize how it works.
any better way to help muggles to use the potential of narsil is highly appreciated :)
I’ve got some YouTube videos in my sig.
I have just received my 2 GTminis but there is something wrong with one of them. It has no turbo mode! After a double click the output power is the same as in high, only the color temperature gets a little cooler. Also the defective one has worse centered LED in the reflector.
Both lights were ordered NW and they are the same color temperature all the way through ramping, both powered with freshly charged sanyo 18650GA
