This may have already been discussed earlier. But is it possible to mod the light to a different aux led? I don’t love the blue. Would much rather green or even red. Is this doable?
Here’s what the AUX LEDs look like on the meter. This is with the optics and a slight Zircon minus green on top so on the CIE graph the LEDs would actually sit just a bit higher.
Regarding the step-down rate. Keep in mind that if you don’t start on turbo, you should have longer before the light steps down from your initial output levels.
When setting the ceiling, 1 click sets it to 150. 2 clicks set it to 149. 3 clicks for 148. And so on.
I’m still not sure I understand the question, but this is how I recommend configuring that:
Look at a thermometer. Mine says 22 C, so we’ll use this value.
Go to thermal config mode.
Calibrate the sensor: At the first “buzz”, click 22 times to tell the light it is now 22 C.
Wait until the light shuts itself off. If you haven’t changed the value already, this should leave the temperature limit at the default value of 45 C. Otherwise, you could click 15 times at the second “buzz” to set the limit to 45 C. (limit = 30 C plus N clicks)
I received my D4S from Hank today. XPL hi equals on happy fat guy in a wheelchair. Civil twilight at 8:24 pm EST. Toykeeper and all involved THANK YOU VERY MUCH!!! All caps very intentional
TK said they were usable for a night pee streak, albeit a bit variable in beam.
Guess it won’t bear up to evaluating your kidneys’ processing of local brews.
I find the low aux LED mode works well as a replacement for tritium vials. The high mode is more like a blue moon mode with longer runtime and a weird-looking beam.
Anyone notice d4s turbo mode response faster ? I did… double click to turbo and another double click to return to previous mode function is faster than d4. Lmk what you think…
