This may have already been discussed earlier. But is it possible to mod the light to a different aux led? I don’t love the blue. Would much rather green or even red. Is this doable?
Shockli 26650 IMR 5500mAh
Here’s what the AUX LEDs look like on the meter. This is with the optics and a slight Zircon minus green on top so on the CIE graph the LEDs would actually sit just a bit higher.
Regarding the step-down rate. Keep in mind that if you don’t start on turbo, you should have longer before the light steps down from your initial output levels.
The floor is N clicks, to set it to level N, or 0 clicks to leave the current value unchanged.
The ceiling is 151 - N clicks, so 1 click for 150, 11 clicks for 140, 21 clicks for 130, etc… or 0 to leave the current value unchanged.
The ceiling is basically off by one to make it possible to set the ceiling to turbo.
Are there any good beamshot pictures for this yet?
Do I see what the die/phosfor of the ice-blue aux leds produce or is some of it also the main leds excited by the blue aux leds?
There are 150 levels.
When setting the ceiling, 1 click sets it to 150. 2 clicks set it to 149. 3 clicks for 148. And so on.
I’m still not sure I understand the question, but this is how I recommend configuring that:
I received my D4S from Hank today. XPL hi equals on happy fat guy in a wheelchair. Civil twilight at 8:24 pm EST. Toykeeper and all involved THANK YOU VERY MUCH!!! All caps very intentional
So, is the XML HI worth the $18 upgrade and is that how you get the 4K lumen?
I’m not worried about throw. There is nowhere in my yard that is further than roughly 500 feet before the treeline.
If I need more throw than that, I’ll grab the D1S or the BLF GT.
I definitely think so. Again THANKS to all who developed this!!!
Mine just arrived as well.
Happy Strayz….
Nice . I am loving it too… 4 or 5 years ago, this kind of light cost around $230, and output around 3000 lumen…
Mid $60 is hella a deal, and you are getting 5000 lumen…
Going to need more 26650’s this waiting for a cell to charge stinks… I am thinking I need to order 3 more.
Side note, turning the aug leds to high is a lot brighter that I thought that they would be.
TK said they were usable for a night pee streak, albeit a bit variable in beam.
Guess it won’t bear up to evaluating your kidneys’ processing of local brews.
I find the low aux LED mode works well as a replacement for tritium vials. The high mode is more like a blue moon mode with longer runtime and a weird-looking beam.
Buy it from mtnelectronics if you are in US. They only got 103 in stock… selling quick…
Not all varieties at Mtn are in stock.
I bought 6 of them… those are the best.
Anyone notice d4s turbo mode response faster ? I did… double click to turbo and another double click to return to previous mode function is faster than d4. Lmk what you think…
Seems the same to me but my D4 is the Nichia so it could be emiter or some other variable that Toykeeper will have to let us know.
And Dam this thing is bright! playing with it here in the office and bounced it off the monitor, x-rayed the eyelids. We all do it. Quit laughing, because we know you are going to do it as well, or something else just as reflective. I am surprised that at this point Dale is not working in a room painted flat black, lined in black felt, Or he wears torch goggles.
