Yeah itās not my meter, I just canāt get the light to do anything but double flash when testing. Maybe Iām not fast enough with tapping the leads. I donāt have any problem on non-rampng lights. Iāll switch to the other mode group and try again today sometime.
keep the wire in place - No tapping
just operate with the sideswitch
Swib, technically the XP-L HI is not a de-domed emitter and itās certainly a different beast than a de-domed XP-G2, so these will have different focus requirements. That inverted V shape is indeed a good indicator but 1 meter is entirely too close to reference point-of-focusā¦ a really strong thrower has that point many times further out.
I like to view the emitter from the front, inside the reflector, and see how far back you have to get in order for the yellow phosphor to fill the reflector, that usually shows where the focus point is.
As far as determining just where to position the die surface in the reflector, without the schematic on the reflector it can be a hit-or-miss proposition and simply a hands-on trial basis to find what works best in a particular light.
Good luck!
It sure is hit and miss. I have a bag full of centering rings because I often sand off too much and start seeing the numbers go down on my meter.
:person_facepalming: Iām so used to measuring tail switch lights I didnāt even think of the side switch. Thank you.
swib try different batteries to rule out that atleast. weird one guy gets kcd in the 140 range u in 110ā¦ too much difference imoā¦
With the 30Q I use for testing I get 5.15 amps and with a slightly used VTC6 I get 5.48 amps and 120 kcd (with correction factor applied to my readings). Maybe itās time to retire the old 30Q.
IMO the difference in output could be due to a higher Vf in this particular led. As I said it will find a good home where it will be appreciated.
Mine is still somewhere between the
AĪ©ā¦ā¦ Apparently lost & confused in itās search for the USAā¦ā¦ :person_facepalming:Latest Tracking Info below.
2018-08-03 22:46
Guangzhou, leave Guangzhou send to Guangzhou courier company
ā¦ā¦
2018-08-03 22:46
Guangzhou, leave Guangzhou and send to JFK Airport in New York.
ā¦ā¦
2018-08-03 05:34
CHINA, GUANGZHOU EMS, Processed Through Facility, Your item has been processed through a facility in GUANGZHOU EMS, CHINA at 5:34 am on August 3, 2018.
.āāWe are all travelers in this world. From the sweet grass to the packing house, birth till death, we travel between the eternities.āā - Prentice Ritter
UPDATE: I am still winning the battle of no new or recent tracking info.
^ Same here, but never got the overnight in NYC. Been in china the whole time. I check it a few times a day at this point. Itās like a sickness.
Try checking again, mine was in the same state as yours, but just updated (like, less than an hour ago) to āArrived in New Yorkā.
teacher:UPDATE: I am still winning the battle of no new or recent tracking info.
Thanks for that info Delta_V & congrats to you on some movement in your Mini GT tracking. :+1:
But I just checked and āno joyā for meā¦ The āstatus quo of no updatesā for me & mind continuesā¦.
Delta_V: teacher:UPDATE: I am still winning the battle of no new or recent tracking info.
Teacher ā I think you should go double check your mailboxāyou might have missed it in thereā The box was much smaller than I imagined it beingā
August 1, 2018, 6:33 am
Your item has been processed through a facility in GUANGZHOU EMS, CHINA at 6:33 am on August 1, 2018.Origin Post is Preparing Shipment
July 31, 2018, 5:55 pm
Acceptance
CHINA
Iām thinking it shipped by boat because Iāve had other orders from China placed on the 8th arrive by now.
teacher: Delta_V: teacher:UPDATE: I am still winning the battle of no new or recent tracking info.
I already did that my brother, in fact I broke out the magnifying glass as well as binoculars to double & triple check.
Stillā¦ā¦. no joy. :cry: ā¦ .
Yep, either boat or a ātrained birdā that keeps getting lost. .
Donāt know if it helps, but I ordered mine on Aug 7, received it on Aug 20, this is Mid-Atlantic.
USPS:August 1, 2018, 6:33 am
Acceptance
CHINAIām thinking it shipped by boat because Iāve had other orders from China placed on the 8th arrive by now.
Yeah, Iām definitely a little disappointed. I hopped on the preorder, but I feel like Iād have gotten it by now if I had just ordered through BangGood instead. They even have coupons floating around to get it at the same price.
Mine was from Neil, not BG
Acceptance
If it was my guess, its on the Titanic. Just a thought.
Great, now I have to call James Cameron
happens more often than we notice...
btw: it would be great to have the discussion focussing back to the flashlight
and maybe open an new thread: The Trackinf F5ers :p
happens more often than we noticeā¦
btw: it would be great to have the discussion focussing back to the flashlightand maybe open an new thread: The Trackinf F5ers
Its hard to get back on topic if most dont have the lightā¦lolā¦but i will try to stay on topicā¦at least your thred is getting a bump.
