The BLF GT70 "Giggle Monster" is here! 7,500lumens, 1,500m throw! Group buy Closed!
There will not be a dedicated warm tint anytime soon. It is about a 50/50 chance of 4000k (which some might consider to be on the warm side) and 5000k at this point.
Okay how about neutral?
The neutral tint LED’s should be ordered this week. How long it will take them to get to lumintop is unknown at this time as it will depend on how and where they are ordered.
With this new shorter battery cradle, will a flat top battery make good contact/connection in it?
No, the new carriers still have the polarity protection boards installed. These would have to be removed to use flat top batteries.
Better to solder blob the batteries IMHO.
Hi.
My GT70 has the “new carrier” and battery over 67.30 mm will NOT fit…
If somebody else has measured something else please update.
I have an extra set of Stock BLF GT35 battery carriers (better fit for protected batteries) if someone in the U.S. wants to trade for their GT70 shorty carriers, they are like new…?
So what do you want to change?
If Lumintop keeps the new shorter carriers, I will remove “protected”.
Thank you!
@Mark M
Writing the manual and checking if everything is OK would be easier when the writer has a lamp to compare.
But there is never one. Only asking stuff via emails.
:wink:
I only mentioned that because there are some minor grammatical errors. Not because of the carriers. I was unaware a forum member wrote it. :smiley:
@TK
Oh, you made the shirt the wrong way.
Text and pics on a shirt like this need to be upside down, so you can read it.
:slight_smile:
Does the BLF GT70 have a battery low-voltage protection like in the Sofirn flashlights?
How do I know I’m not pushing the non-protected batteries too much when using the flashlight?
I like blf gt so much and now I own 4. Lol
I’m fairly sure it will shut down, and I don’t believe you’ll be able to push the 30Q’s to far, you can run this light on 4 batteries, actually I think it will run on one if I recall. I can assure you that there’s nothing to worry about especially when TA is behind the drivers functions.
Newlumen, are those Astro’s on both ends?
If so how are they ? Been looking at those and thinking about getting one but really they look like knockoff GT’s, still tempted though… ha ha
I’m Addicted to anything that lights up.
I read the user manual and didn’t find mention of auto shut-off when battery voltage is low.
I think that information is worth inclusion in the user manual if Lumintop decided to revise the user manual.
Gives the user more fun in using the flashlight knowing that it will auto shut-off or give some conspicuous signal like flashing of light when the battery voltage reached a certain low-voltage level.
I don’t know what will happen If I let the flashlight drain the batteries down in use. Will it explode in my hands?
Hey Verge on the first page of the user manual titled Safety precautions which was for the GT XHP35 but same thing as the GT70 it says on section 4,
Remove and recharge cells when the low voltage indications is given by the GT (repeated step-downs in light levels and eventual shutdown of the light.)
Direct quote for you friend, so have fun and no worries… :slight_smile:
When voltage reaches 3v it will blink 3 times and step down to a lower level. I think it will shut off the light completely at 2.8v. (Don’t qoute me on the exact voltage) So there is no chance of over discharging the cells.
There is a small amount of parasitic drain when off, though. So if you don’t plan to use the light for several months, it’s best to turn the tail cap to cut all power.
The emitter is 12v so you have to have at least 4 cells in a carrier. The other carrier can be empty if you want.
Yes… astrolux mf04 xhp35 cw and mf04s xhp70.2 cw… mf04s is really nice light but little bit green… lumen spec is very similiar to blf gt70…
you probably won’t have any hands if it explodes :open_mouth: …. :smiley:
