How many others have the same issue with the diffuser? I emailed Max just tonight about the exact same issue. Two minis and two diffusers and neither can be used for anything but being used as a lamp with the light tail standing.
Got my GT Mini with the diffuser from Neal too. Yup, the diffuser is a bit loose on the GT Mini (diffuser will generally fall off when GT Mini held upside down). however, the said diffuser fits quite snugly on the ROT66, so I’m using the diffuser with the ROT66 now…
I don’t have the diffuser, but maybe you guys could get a tighter fit if you put a piece of tape around the bottom, inside edge where it slides onto the light.
IDK, I don’t think a piece of tape would be enough. I’m not home right now, but from what I remember, if the Mini GT has an outer diameter of 50mm, the diffuser had an ID of 52-54mm. There was definitely several mm of play between the two. Would almost need a thin strip of rubber or something.
Didn’t order a diffuser but might I suggest you heat up the diffuser (slowly) with a heat gun and then deform it into a more oval shape (near the opening).
This is dependent on type of plastic of course, but it may work to keep them on better.
Get yourself a hose clamp that will fit around the diffuser. put the diffuser on the flashlight head, put the hose clamp on and tighten it up snug. Hit it with a heat gun, and let it cool back off
Or, for an even tighter fit, find something that’s just a bit smaller diameter - by a half millimeter or even a full millimeter smaller. Tighten it around that object and heat it up. Then, it should maintain a tighter fit when it cools and you put it on your GT Mini.
That ring should not be pressing it down super hard. Use your thumb to press down and rotate the rubber button. Maybe disconnect the power first. It should rotate.
If that doesn’t work, you’ll need to try using a single edge razor blade to very carefully get between the ring and the body. Just pressing it in should lift the ring slightly. You run the risk of scratching the body and cutting yourself, though.
That’s the only way I know. That style of ring is a press fit and not designed to be removed.
On the picture above is the white bumper to the left from the black button-top is the thing that preventing me normally operating the light? Is there a matching indent in the rubber cap?
I don’t know what you’re referring to by white bumper. The black switch sticks out about 3 mm and the rubber switch has a semi solid rubber core running from your finger to the switch. Here is the other side of the button.
If the button is not rotated correctly with the light source on the bottom, the switch might feel funny or not work correctly.
