New VirEnce MCPCB for E17/E21/119/144/233U
Disconnect all the wires first. Then test each LED individually. It’s easier to only fix where the short occurs. It’s possible you heat it for too long and the solder bridged. If you can’t fix it, you can send it back to me or anyone else near your area who did the reflow of this LED before. E21A is indeed harder to solder than most LED.
- Clemence
Has already detached
I called each diode individually
None burns
Tomorrow I’ll try to warm up on the kitchen ceramic stove at 200-210 degrees Celsius
Exquisite color rendering
The picture was taken in RAW format
By pipetting the white balance is set
Thank you Clemence
VR16SP4 , 4 x Nichia E21
- Combined LED voltage: … 3v Configuration
- LED1: … sm503-D220-L2-R9080
- LED2: … sm403-D240-M1-R9080
- LED3: … sm503-D220-L2-R9080
  • LED4: … sm403-D240-M1-R9080
Nice scene choice!
I saw it before in your email attachment. Too bad, the Optisolis still not feasible for most flashlight applications.
- Clemence
I just received the 5 Tiara C1 Pros modded with 4x E21A from Virence.com and I am very happy with Clemence’s work! The packaging of my emitter/mcpcb order was phenomenal too! :+1: :beer:
I love the E21A tint especially the 2500k and 3000k version, which is perfect for bedside use. They are rosier tinted than the 3000k 9050 219B bedside EDC I’ve been using, which I already thought looks really nice. The 4000k is slightly rosier looking than my 9050 219Bs but not as rosy as the Cree 5D tints on the Emisar lights. However, it looks noticeably cooler than the Cree 5D tint. I think the 219B 9080 will be even better looking tint wise if you prefer rosier tint. I took lumen readings at 1sec (turn-on) using the TA Tube calibrated with Maukka calibration lights:
Tiara C1 Pro 4000k - 572 lumens
Tiara C1 Pro 3500k - 539 lumens
Tiara C1 Pro 3000k - 529 lumens
Tiara C1 Pro 2500k - 438 lumens
Tiara C1 Pro 2000k - 407 lumens
Lights were running with fully charged Aspire 18350 1100mah batteries. I doubt it matters what batteries I use though since the amps are pretty low. But the output is quite impressive given how small the Tiara is and how good the tint and CRI looks.
Also, since you aren’t pushing much current on very low VF quaf E21A, you will get full regulated runtime.
Hello Clemence,
Could you test your VR21P4 loaded with Optisolis with Carclo 10623 or 10624 optics? I think, if the beam is properly even, that would be good for using them in a short (and wide head) 18350 flashlight. With 1.6-2 A (400-500 mA per LED), that would make a very usable 400+ lumens (500+ for 5000K and 6500K CCT).
Do I guess right, that the 4 different rotations of the emitter with the centered TIR over them should balance the beams produced by the off-center light emitting surface?
I have no Carclo 10623/10624 but frosting the 10622 with #320 grit SiC already fix the beam very well.
No, with only 4 LEDs, rotation will only make the beam’s hotspot weighted to one side. The LED’s die hot spot is too asymmetrical it requires at least 6 LED in rotation to get even beam pattern from a tight plain TIR optic. So far, the best fix is to use the tightest Carclo 10621 paired with Luminit’s 30° - 80° LSD.
- Clemence
If you refer to this, can you link retailers, where I can get it?
Another (non-flashlight) question. Did you consider getting an MCPCB manufactured for Optisolis, which has: 16 or 24 emitters, and can be configured into 4S4P (4S6P) or 8S2P (8S3P) for 12V or 24V voltage requirement. I think, if Optisolis is not the best for flashlight usage, it would be very tempting for ceiling light panels. If there would be such panel, I’d be a definite buyer for that (3-4 of these panels could nicely illuminate a bigger room).
Work in progress…. :wink: Seamless module you can combine it to make unlimited larger panel of light.
Yes, that’s the correct Luminit. Will put some in the store too. Try to contact Edward Udarbe in Luminit, he’s the marketing manager. But be prepare, it’s a very expensive, aerospace class diffuser. Luminit just launched the cheaper version for earth dweller like us.
- Clemence
It would be just perfect! Very good to get these good news! :+1: I just told my father about Optisolis, and this way of its possible usage about a week ago (and I told him, that I will contact you). You already read minds :beer:
Aw. So this would be good for occasional custom builds, but probably won’t be competitive for using in a manufactured flashlight.
Is there 16 leds module https://www.lumitronix.com/en_gb/aventrix-4x4-v2-led-module-16x-nichia-757-leds-4000k-cri-80-31989.html
a quadtrix e21a or a quad optosolis 4000k for LEO use. which one?.
Easy Nichia E21A soldering on Virence VR16SP4 MCPCB
Part. 0 (forgot to make it, Kaybi made me shot this one)
Pre-soldering the Indium to the MCPCB
Part. 1
This is a quick and dirty video I made with one of the order. Sorry for the quality, it was hard working with only one hand.
The MCPCB was first pre-soldered with Indium at the LED pads. I simply add some flux (common water based Zinc Chloride) and ran the molten Indium balls until all pads properly wet and contained sufficient Indium blobs. Be careful! This nasty flux will corrode aluminum instantly in contact (above 50°C). I did all the soldering on my upgraded “deluxe” cloth iron hot plate. Temperature regulated and monitored to 160°C (+/- 5°C)
Next, I cooled the MCPCB and carefully placed the E21A in approximate locations. Reheat the MCPCB just enough until all the E21A stuck to the pads. Cooled the MCPCB, added some more flux and reheated the MCPCB. Voila! it’s done with minimal efforts.
Part. 2
Ultrasonic Cleaner post cleaning. The water based flux makes it very easy to clean all the flux residue leftover, even from underneath the LED! The liquid ingredients: distilled water, dishwasher surfactant agent, and some dirt from previous cleanings. I did final rinse in a clean water (using glass beaker submerged in the USC)
Result:
Perfectly centered!
- Clemence
Very nice!
Do I see some layers of asbestos cloth on top of the iron?
Nice work on the indium soldering!
Yes, I put asbestos cloth and then drywall on top of them for my palm rest for better control. As a side bonus it makes the iron heats faster, very effective insulator.
- Clemence
Hmm, isn’t that toxic?
Because I lost my rock wool insulating brick. This asbestos supposed to be temporary replacement.
- Clemence
Well , YOU make it look easy ! :slight_smile:
