Hi HKJ, I would have another suggestion to make you on a cell of a format little standard, the “Zhiyun IMR 26500 3600mAh / 13.3Wh” or existing also in another version of rewrap the “EVO Gimbals IMR 26500 3600mAh / 13.3Wh ”, I would be curious to know the continuous discharge capabilities knowing that the device that uses them (the Zhiyun Crane-M for example, a stabilizer) can fired up to 6 continuous amps. Here are some pictures and links to places where you can buy them.
Cells rewrapped by Zhiyun
Cells rewrapped by EVO Gimbals
Cells with their original wraps
Extract from the technical paper Zhiyun Crane-M regarding electrical consumption and battery used.
I do not mean to sound too judgmental, but the price of these Zhiyun cells is offensive, outrageous. Totally looks like whoever has designed such device is just trying to milk the cows. Seems like the previous version of the Zhiyun used standard 18650 cells, they could have gone any other industry standard format this time, like 26650. This totally smells like I said above. If it were me, I would say some kind :| words to that people in that regard.
All depends on the site where you buy them because I only gave links for purchase as an example, it is not the best prices of the net that I chose specifically, for example look at this one: https://www.hobbygaga.com/en-2pcs-3-7v-3600mah-26500-battery-for-zhiyun-crane-m-gimbal-p274006.htm , the price of 2 batteries 26500 3600mAh is 12.89 € ie 16 $ This is not very expensive for two cells in this category.
The following are only a few suggestions, first two LiFePO4 cells for which I'd like to se how accurate are their ratings (33A continuous and up to 1800mAh in 18650 cells is interesting):
I remember having suggested the Samsung ICR18650-32A in the past here (#384) and there (#465), guess it was forgotten and/or something went wrong… :???:
How about the above LiFePO4 cells? Heter is a quality cell manufacturer, but I have seen next to no reviews of its cells.
Good question with the 32A, I have tested them long time ago, but did not publish it when I found out it was at the wrong voltage (4.2V charge, they are only about 2700mAh at the voltage).
I have some cheap LiFePO4 in queue and I may also look at your last suggestion, but 20S is not in stock.
The following is a few suggestions from a seller in AliExpress who is rewrapping some kind of chinese/korean OEM cells or whatever. Noticed the ukrainians behind the video in the thread “Testing 18650 Safety - Russian Style” were using EAIEP 26F pink wrapped cells, cells which totally look and seem to behave like some fake 25R cells I got months ago. Decent and cheap stuff:
Mmm, none of those EAIEP offerings look appealing?
We can be glad we can buy lots of first OEM batteries in their original industrial wraps, which is because brave retailers manage to get and market them. However, due to the li-ion battery OEM to consumer sales reluctance/reticence I do not see an easy way to buy non-first OEM (LG, Murata, Panasonic, Samsung) cells except with a non-OEM wrap.
China is still a bit of an isolated land with certain good OEMs and products. Since the unit price of these cells is super affordable they could be top candidates for a large battery pack, of course for as long as their performance and consistency are decent at the very least. The aforementioned ukrainians were building e-bicycle battery packs with them.
May we know which ones? A little birdie told me the wide triple leg pink wrapped “26F” cells come from BAK. I may delve in a more detailed identification if I can find some chinese indigenous lad willing to cooperate.
LoL thanks. I'd have likely chosen the same models. Both 33E and VTC7 seem to use the same cell underneath and I wonder if they could be rewrapped LG MJ1 cells. With respect to the penta-leg top 25Rs, no idea.
That cell is likely to use one of the top OEM available high capacity cells, maybe an LG M36.
I believe there are no alternatives of equivalent quality.
It seems that most of usb-rechargeable 18700 cells use 18650B or similar cells, low discharge and OK capacity.
Klarus has used 18650GA in their cells before in their “3600” cells and I expect that’s what’s inside this one; better at both discharge and capacity than others. Though yes, it may come with a M36 or something similar.
Aside from a better cell this might have a lower-resistance protection circuit as well.
sharply curved or having an angle.
“a piece of bent wire”
synonyms: twisted, crooked, warped, contorted, deformed, misshapen, out of shape, irregular
2.
INFORMAL•BRITISH dishonest; corrupt.
