Cutting the plastic washer out as a spacer didn’t help anything. With the spacer in place and the retaining ring on the light works fine, put the boot in and same glitch, mostly just a blink at the emitters and nothing.
This plastic washer was cut out of a credit card, I can feel the play between the boot and the switch post so I know the boot is not touching the post at rest. Still, doesn’t work. Works fine without the boot, just not with it.
The switch pcb is oblong, fitted into the switch compartment, and the switch itself is not in the center. So my plastic washer looks out of round but it is indeed true and matches the boot just about perfectly.
The above pic is with the light in lockout, holding the switch for momentary moon to show the sliced Samsung LH351D’s…
And now I ask, what is up with the design? Why did they not cut fins in the section above the switch? Only the opposite two sides have the new fins. Also, this one shows a slight shelf below the flat of the switch, was that a glitch or are they all like this? Don’t see the point in cutting that…
How about attaching some stiff plastic of the right thickness to the bottom of the boot? I guess that stiffening shouldn’t hurt. And extra thickness will make it touch the button at rest.
I get 11.76A at the tail with my Uni-T clamp meter, but only 3032 lumens out the front.
Edit: Remove the lens and it does 3236 lumens… the lens is costing 200 lumens straight up.
Edit II: Oh, and the amp reading is of course no tail cap, the lumens readings are light assembled with a large Omten switch on the PCB. (replaced the thicker stout looking factory switch)
I have both the 18650 C8F and the 21700 C8F and have just tried various batteries.
I use a lux meter app on my phone and get 460 lux on the 21700 C8F using a Liitokala 4550Mah 21700 and also using a 30Q with the adapter. I then used a Samsung 30T 21700 battery and got 560 lux. On the 18650 C8F I get 510 lux using a 30Q.
So the 18650 C8F does outperform the 21700 unless I use Samsung 30T’s.
My 21700 sofirn c8f got only 7.22A used UT210E clamp meter and got 2,678 lumen. I use fully charge sofirn 21700 4000mah battery that come with the lights.
Finally have my 21700 C8 host working with the rubber boot installed. I had made a shim to be sure the boot wasn’t holding the button down, didn’t work. So today I used my Proxxon rotary and carefully reduced the length of the brass post coming up out of the switch. Put the boot in (shim still in place) no worky. VERY obvious space between the post and boot, but no good. Without the boot it works fine. So, I looked around on my table and found the black plastic tray some FET’s came in. What they call the “tape”. I cut the bottom out of one of the containers and placed this inside the boot, removed the shim, put the light together… and it works! The rubber is soft enough that the switch depression rebounds and Anduril doesn’t recognize the press. So now with this thin bit of plastic in there it gives a positive enough click that Anduril sees it and the light works fine. Go figure…
I think 6-emitters would be the grail C8. I think LED4Power is coming out with a kit for the Sofirn 21700 C8F. Hopefully Kiriba-ru will make a copper spacer for this as good heat sinking is critical if we want to max the output.
Eh, your talking about TIR optics, though. There’s already a lot of lights out there that use multiple TIR lenses. The really nice thing about the C8F is that it uses a reflector. Now if we could get a 4 or 5 emitter version with a reflector, now that would be really cool.
Someone made a 7x reflector C8. But the head is huge. Don’t think we can fit more than 3 reflectors in a practical C8 form factor. Why is TIR bad? I think you only lose 5-7 % output compared with reflector.
