I think the only way to turn them off is to disconnect the battery. If I understand correctly, the aux LED board is connected directly to the battery, so the attiny cannot control it.
Is that the direction that Fireflies went? They didn’t wire it into the MCU controlled side switch light? I guess the easiest way to find out is if the auxiliary lights turn off and on in sync with the switch lights.
People were talking earlier about the ROT66 being sensitive to bumps. I wasn’t able to make mine do anything wrong though, even with fairly short cells installed. Anyway, today my ROT66 fell about 1.5m onto a linoleum floor… and it didn’t even skip a beat. No change at all in the light output, and no visible dents or scratches on it. I’m not sure the floor is completely intact, but the light is totally fine.
Since I have my ROT66 in front of me. I decided to put it on turbo and hammering it against my palm repeatedly with a lot of force and did not see a single blink. I have the stainless steel tail cap but I doubt that makes any difference at all.
SKV89 know that you are crazy about the quality of light and that’s why I’m curious what version you chose. What LEDs ?. I think about ROT66 myself, but Nichia is too much under BBL.
I bought 3 ROT66 with 219B. One for my friend and two for myself since these emitters are supposedly going extinct… I was going to buy an XPL-HI 3A v3 version too but will wait until they get the manufacturing issues fixed on that one.
It really isn’t much rosier than the 5D tint Emisar flashlights that I have. In fact, it’s not even as rosy as the XPG2 in the Enogear AA Stainless Steel. Now I’m so used to it, I don’t even notice it’s rosy. I thought something went wrong with the emitters after too much use. It just looks natural white to me. However when I compare it with my other non A or D tint flashlights, they all look yellow/green. At night, when I use it on natural vegetation, it is the closest to sunlight I’ve seen. I love it!
I can say, that the FB4 tint of SST-20 is already much better than Nichia 219C regarding perceived BBL position.
I have Nichia 219C 4000K in a Lumintop IYP365 penlight, and I have a Jaxman E2L as well with the same LED as comparison.
I just finished a rather simple Convoy S2+ build with TIR lens and a 7 mode driver (10-100%), and I tested it with a 25 degree beaded lens on an evening bike ride. While I still like the tint of 219C 4000K, I can notice, that it is noticeably greener and yellower than the FB4 SST-20. Also, I can ‘feel’ the slightly better spectrum coverage of the latter.
I have also 4×E21A 4000K from Clemence in a Skilhunt H03 - that felt me a little bit warmer, and it has a slight further extra ‘touch of’ deep red, but FB4 SST-20 is already very good in deep red.
lol. Basically I have a few friends that got inspired by my flashlight collection and whenever I see something super interesting, I let them know and see if they want to buy it. If they do, they just pay me back the cash and they can avoid the hassle dealing with the online transaction. This friend who just got the ROT66 219B is a 5700k fan. He seems to like the 4500k ROT66 but hasn’t compared it side by side with his other lights yet.
I bought a 4xE21A 4000k Tiara Pro from Clemence. The tint and color rendering on that thing is perfect. Also the Tiara Pro is regulated even on high mode so I can run it with 500+ real lumens continuously, which is great as a work light.
My ROT66 (nichia) is from the first batch with GITD and is prone to cut off with bumps but it doesn’t bother me.
Until now I never found a true rival to an HDS with Seoul SSC P4 high CRI. The ROT66 looks green compared to the HDS which seems to show deeper or more saturated colors. Red, blue, yellow, orange, etc look better, more natural than with the Nichia 219B SW45K.
Jk skv. I know this rot66 doesn’t make over 10,000 lumen, but the tint, size, quality, and firmware make it more desirable light. we got atleast 5 people that bought 2 or more rot66 including me…
The SST20 4000K has a nice tint. It looks very similar to a 219B 4000K, so I think people will be very happy with it. I personally think 4000K looks yellow, even when it’s a good 4000K tint, but a lot of people really like it. I’ll try to get some beam shots later, to see if my camera picks up anything weird.
The aux LED board is wired to BAT+ and BAT-, so it does not turn off… even while the main emitters are on. I’m hoping I might be able to convince Fireflies to attach it to the button LED pin instead, so that it can be turned on and off by the firmware. I need to test that first though. So far though, here’s what it does:
3.3V or above: blue, with both outer rings of LEDs on.
3.0V to 3.3V: Red, inner four emitters only.
below 3.0V: Off.
I measured standby power usage too…
BLF Q8 standby, button LEDs in low mode: ~30 uA
BLF Q8 standby, button LEDs in high mode: 100-130 uA
ROT66 without aux LED board: ~120 uA on “high” mode (all 4 button LEDs at full power)
ROT66 with aux LED board, 4.2V, pots trimmed to maximum power: ~620 uA (blue)
ROT66 with aux LED board, 3.3V, pots trimmed to minimum power: ~230 uA (blue)
ROT66 with aux LED board, 3.1V, pots trimmed to maximum power: ~350 uA (red)
ROT66 with aux LED board, 3.1V, pots trimmed to minimum power: ~210 uA (red)
ROT66 with aux LED board, 2.9V: ~100 uA (aux LED board shuts off below 3.0V)
Based on these numbers… The standby time, with 3x3000 mAh cells, should be anywhere from 1.5 years to 9 years.
I haven’t taken things apart yet, but that’ll happen soon.
