Fireflies ROT66 Flashlight
Product Description:
9x CREE XPL High Intensity Emitters / 9x Nichia 219B SW45K R9080 High CRI Emitters
Made of 7075 aluminum alloy
Body color: champagne color or Black color
HAIII Anodising Surface Finish
Stainless Steel bezel;
Max Brightness: 10 000 Lumens (9xCREE XPL Hi CW V3) / 5000 Lumens( 9x Nichia 219B)
3x18650 battery carrier
25 degree angle TRI lens
98% AR coating glass lens
Digital current regulation on lower brightness
IPX8 waterproof , underwater 2 meters
Size: 110mm x 47mmx45mm body
Weight: 240gram
WOW, what an entry!!! Welcome to BLF ^:)
First, enjoy the forum.
Then, some questions: are you a manufacturer? Can you post some beamshot images of the flashlight, please?
I went to the site (http://www.ff-light.com/index.php?route=common/home) and only saw the flashlight’s pictures, no beams! It would be pleasant to get some O:)
Very nice!
I like the stainless steel tail cap as well, nice touch!
What sort of information can you share about the driver?
Thank you. yes , we are a manufacturer . beamshot photo ,let the reviewers from blf do it, they should receive package soon. :beer:
narsilm v 1.2
Very nice light indeed. Can’t wait for a review. :THUMBS-UP:
And welcome to BLF!
thank you sir :THUMBS-UP:
Nice, let them show us your lights :wink: ^:)
That is not a bad firmware, but I was hoping to find out things like: is this light using a combination of linear regulators and a field effect transistor (common 7135+FET drivers) or if perhaps the battery carrier puts the cells in series so as to use a buck driver, or maybe the cells are in parallel but the leds are in series and a boost driver is used. I worry that a FET would not be good for the 219b version.
I suppose once the sample reviews come out I will find out either way.
The battery carrier is in parallel, that is easy to see as the springs are all in the same direction.
And it is probably using a 7135+16x7135+FET driver.
The springs are a good indicator, but not absolute, which is why I asked. Yeah, that seems likely but I sure don’t like the idea of FET and 219b, even when it’s 3:1. Seems likely that a bit too little resistance could be an issue.
Looks great!
Any chance of there being a 4000K or 4500K neutral white XPL HI version?
Awesome. What a beautiful flashlight. My new ‘must have’.
Yes, 4500K~5000K XPL hi V2 are available
Price?
I believe the website said $98
Whoa, is this the first factory light with 4500K R9080 Nichias?! :LOVE:
Can you share photos of the driver?
Wow I havent seen anything that got me this excited in a long while! Is it really 219b 9080? Becaise from my understanding Nichia discontinued them a long while ago. Only Virence.com sells them but with very limited quantities left. If it is really 9080, I will definitely buy one or maybe two if performance is good. Thanks and really looking forward to learn more about this light
