Ah, true, it’s on the 12A setting. Will actually probably reduce it a bit as it does get hot fairly quickly. lol Thanks for reminding me, I knew it had the DD setting but just forgot about it… :person_facepalming:
Some years back, on my birthday, my wife and daughter gave me a T-Shirt with the text (across the front) I DO know it all! I just can’t remember it all at the same time.
Is it an idea or at all possible to have centering pieces made for 3030 Oslon-sized leds like the KW CSLNM-TG? For the various reflector hole sizes around?
I find centering the one major frustrating part of using 3030 leds, a fitting centerpiece would help bigtime. I have no access to or skills with 3D printers plus that I fear for the low melting point of printable plastics.
I used cheap solder paste(mechanic) we mostly use here. But very little(applied with needle syringe) Also best performance somewhere at 5.8-6A I could not define correctly as other guys with better equipment. I just have uni-t clamp meter and lux meter for testing purposes.
And I am definitive not getting any angry blue at even more than 7A after more then 3 minutes on samsung INR 30Q.
But that maybe also depends on used rig. Mine was in dd mode with fet driver, single 18650.
But I think that Djozz test also represents well how this emitter work. Some may get higher peak and some lower depends how they will reflow or cherry pick something.
Remember Kawi, the XSword is only making 370 lumens (for over 2 hours!) but still puts light on a water tower 1.9 miles away. Don’t get to “focused” on the low lumens numbers.
But old XP-G2 S4 2B also deserves to be in that graph cause it has just slightly lower lux performance(and sometimes certain g2s42b can have even better performance than certain black flat).
Sorry about those promises but new osram leds came to me and I had to process bunch of orders etc., always something unexpected appears and limits my time for other stuff.
I will not predict release dates anymore, products will just appear on web,maybe that's better.
