Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
I am also waiting to make a combined order w/ X6 spacer + other things
GND ring is ~1mm wide so sanding driver down to 15mm is probably too much, 16mm would be ok.
Some more checks on the BLF D80 with KW CSLNM1-TG led. (Should this led get a dedicated thread btw?)
First, I was not happy with the quite random centering that twisting a 3535 centerpiece provides, so I modded the centerpiece: with a scalpel I cut new corners 45 degrees from the original corners, fixing the 3030-sized led much better. So the flashlight has two centerpieces, one locked around the other, both sanded very thin at the underside for exact focus, now also exact centered.
With the led perfectly centered in 3 dimensions the beam was superb.
Now I measured throw again, first on the almost full 30Q (4.08V): 140 kcd (as I measured before), then let the light run for half an hour (it got hot, I estimate 70 degrees! A biscotti driver has no thermal stepdown, and a 3.9 amp flashlight produces some 15W of heat), the battery was now 3.59 V, so wel over half empty. Measured throw again and still got 125 kcd.
I did the same test with the same battery on a C8 with dedomed XP-G2 S4 2B. Started at 4.08 V with 141 kcd, and with the cell at 3.59 V I measured 90 kcd.
So the low voltage combined with the much needed current regulation of the biscotti driver makes the output and throw of a flashlight with the new Osram led more constant than a light with a direct driven S4 2B.
Plus the current is a bit lower for the same throw.
Nicely done Jos! Good thinking outside the box with the dual centering rings, very imaginative!
Thanks Dale, I’m very happy with how I got it done. But how I would like some fitting centerpieces for this led!, would make life quite a bit easier.
Thanks for the answer mate :wink: Maybe I should thing reversely, then, sanding the driver till the 16mm and the extra by sanding the flashlight hole!! Thanks again!! :+1:
Nice work djozz. I’d have no hope of achieving a result like yours. :+1:
Hi
LD-B4HV (2s - 8.4v) can use with triple XP-G2 connected in series ?
I did that here: OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
Now I must gather all relevant data and builds into first post of that thread.
No, 3 LEDs in series would have 9-12V forward voltage, 2S cells on the other side have 8.4V max.
Order placed, PM sent :wink:
Have you ever considered making 20-22mm drivers or at least stocking 17~~20 and 17~~>22 quality spacers?
You can buy it on KD
17>20 2pcs
17>20 5pcs
20>22 2pcs
I have a 17 to 20 but who wants to use 2 spacers to go from 17 to 22. Thanks for the 20 to 22 though havent seen that
It would be handy, I would get one to mod my Amutorch VG10 :wink:
I plan to have all sizes for new driver iteration, so until then LD-x4 will stay 17mm only, sorry.
Trying to set the max power of my LD-A4. 10+ clicks enters main menu, OK, 5 fast clicks blinks and power goes down. 1 click enters current adjustment, OK, 1 blink and current goes down again. I click 7 times for 4.75A. I get 15 blinks in response. What’s up?
BTW 30 seconds of idle time was WAY too fast for me, I needed over a minute just to read the relevant section.
That’s right
Correct, now you are in the setting you chose
Wrong, in the “low light” setting, 1 click = return, >= 2 clicks: Setting
You now left the setting and went back into the menu
That should not happen as you left the setting and now are in the general menu
That’s wrong, you now should be in setting 7 (whatever that is)
You can always enter again.
But in that case, read first, note the settings you want and then start configuring…
[quote=zeroflow]
:person_facepalming:
I meant 5 fast blinks, not clicks.
Making notes, that’s a good idea. Still, I believe that making the duration much longer would make the adjustment easier.
LED4POWER, can you tell me tint bin of the LH351D 4000k 90CRI you are selling? It says SPHWHTL3DA0GF4T0Q6, which means tint bin is T0 but there is no T0 tint bin.
Oh NVM, I see description says T6.
