My Emisar D4 is a “touch” light?
51 posts / 0 new
ZED
ZED's picture
Last seen: 1 year 11 months ago
So I’m driving home tonight and my D4 blinks a few times in the seat between my legs. Ok… Probably a loose tail cap (lockout) making connection while I sit on it. I pick it up and it’s screwed on tight but I notice the nichias are very dimly lit.. okay… so long story short, when I’m holding anywhere from the body tube down with one hand and touch the head with the other hand, it glows. Make more skin-to-light contact and it glows brighter. Wth? Now if I hold it and my girlfriend touches the head ( yea yeah), then nothing. So my body is somehow completing a circuit. Is my 30Q gonna blow?
-Zach
chadvone
chadvone's picture
Last seen: 1 hour 39 min ago
Try holding a light bulb and see if you can make it light up.
ZED
ZED's picture
Lol it was one of those “I wonder…..naah” moments at first
-Zach
deleted-200707
Last seen: 1 year 6 months ago
Mine does the same thing… Evil
just not the D4.
chadvone
chadvone's picture
Long long time ago, my grandpa had to have a special watch band, because he had electricity in his body and it would mess up his watches, wind up watches.
You might be a Slider.
ZED
ZED's picture
Lol no anyone can do it but they have to have one hand on the body and one hand on the head. So if I have my hand on the body and someone else touches the head, it won’t work. But if you take that same scenario but I touch the other persons OTHER hand that is free, then it lights up. A circuit is somehow being completed. It’s really weird.
-Zach
hank
hank's picture
Last seen: 6 days 22 hours ago
Problems like this are why the multimeter was invented.
Please measure everything!
ZED
ZED's picture
Agreed, I just wondered if anyone has come across this. It’s not a problem unless it could short something out. Then it’s a problem.
-Zach
AguassissiM
AguassissiM's picture
Last seen: 17 hours 10 min ago
Big Smile ZED Just do not use the multi-meter on your girlfriend or you risk long term shock….
***Rofis MR70*TurnRaise*Catapult V6*BLF Q8*BLF Mini*BLF Micro*Haikelite MT09R* Convoy C8*BLF D80v2 SST40*MatemincoX6S*AstroluxFT03-xhp50.2*AstroluxFT03-sst40*BLF-LT1*AstroluxFT03S-SBT90.2***
moderator007
moderator007's picture
Last seen: 1 hour 22 min ago
Just wondering if this D4 is worn or like new. Anodizing is non conductive.
ZED
ZED's picture
Moderator007 it’s very worn it’s my EDC. And I thought of that and that’s the really puzzling part. If I hold the head with one hand, there’s no light, but I can touch the fully anodized round body tube with just the tip of a finger (while still hold the head with the other hand) and the LEDs glow. It’s so weird. But when I lock the light out by unscrewing the tail cap it’s dark always, which does make sense, because the negative part of the battery would then only be touching the spring and PCB and has no way of conducting electricity anywhere else, even if the threads were bare aluminum, because the pcb is just glued in the tail piece. . None of it makes any sense though yet. FYI I’m not suggesting any mystical magical stuff, it’s just odd.
-Zach
ZED
ZED's picture
But literally one person can hold the tube, hold my hand with their other hand, and then I can light it up with my other than. The current goes through (at least) two people. But we have to be touching each other or it doesn’t work. I wish I could put videos up.
-Zach
chadvone
chadvone's picture
can anyone else do it without you ?
ZED
ZED's picture
Yes, it’s not Zach-specific. Just as long at the two hands are connected. My hands or anyone else’s hands and “our” hands connected by holding hands. Lol. It makes me think a “touch” flashlight would be pretty sweet. Like turn it on with two taps and change modes just by touching. Kind of like a touch screen or apples new home button. A button-less flashlight
-Zach
hank
hank's picture
You’ve clearly got a current leak path somewhere in the head of the flashlight.
Can you post pictures of the negative/ground white wire connection of the driver?
Or ask the manufacturer how to test for a problem so you could get an exchange.
________________
I’m not that Hank
ZED
ZED's picture
Well I have two more D4s on the way, and I’ve swapped LEDs in this one I don’t know how many times. But isn’t there something with the middle pad on nichias? Like it’s not neutral or something? Does the MCPCB get a charge or what if my positive or negative leads are touching the MCPCB? I haven’t taken the head off yet but I bet that’s something to do with it. Just the symptoms seemed quite odd.
-Zach
deleted-200707
My wife has no capacitance. I converted a lamp for her to a touch lamp. No work at all, touch, grab, 2handed throttle…no work. Bought a factory one, same scenario. Works fine as advertised for me & others. Same for touch screen apps….no workee. Is she an alien?
chadvone
chadvone's picture
I don’t see how touching the body and the head could be completing a circuit that should already be completed when you screw the head to the body.
Edit.
I vote for a video.
ZED
ZED's picture
https://youtu.be/614gjgNEwXk There’s a link on my YouTube channel. I don’t know why it always uploads 240p but you can see what I’m talking about.
-Zach
moderator007
Try this, take the tail cap off and lay your finger across the battery and the bottom of the tube.
Does it still light up?
ZED
ZED's picture
Moderator007, no dice. Just tried that. Doesn’t glow at all. It has to be in the driver cause it doesn’t do it when the tail cap is unscrewed slightly. So it’s like how an e-switch needs a small amount of current to work. Maybe it’s leaking by the e switch. I really have no clue. Interesting though right?
-Zach
Virisenox_
Virisenox_'s picture
Last seen: 10 months 3 weeks ago
No idea what the problem is, but I’d love to see some video of this.
https://virisenox.wordpress.com/
More active on Reddit: /u/Virisenox_
"I go hard."
- Zeroair
"Don't quote me on that."
- Zeroair
ZED
ZED's picture
I put a link a few posts up. I put a video on my YouTube channel. If you watch you can see how the pressure of my hand (surface area of my hand on the light) affects the light output. Still it’s all less than a lumen I would say almost certainly.
-Zach
ZED
ZED's picture
And I have to say, normally something like this would bug me like a speck of dust in my reflector—which btw using your tongue really is the best method for cleaning one—it’s actually kind of cool as long as it’s safe. I guess time will tell if it’s safe.
-Zach
moderator007
I kind of think there is something touch in the tail cap. And it maybe very small with no more light than its making.
When you stuck your finger on the battery and the tube should be the same as you holding the cap and touch the head.
I just pulled my D4 out to look this over, the tail is always connected.
moderator007
I’m trying to figure this one out but that’s just strange it acts that way.
Maybe you are just are a good conductor. Too much salt Big Smile .
Lexel
Lexel's picture
I have seen this issue before
The only explanation I can give is that the LED- on MCPCB has a grounding or low resiastance(conductive acid flux) to the head part, easily to check with DMM
But the D4S has insulated driver and Tube usually, so there cant be a current flow bypassing the driver
seen on Lights like Convoy L6 going instantly to Turbo when you turn on on Tail switch
so you act as cinductor between head and Tube bypassing the driver
ZED
ZED's picture
Yeah but think about it. When the batter is in and the cap tightened, the flashlight is energized ready to go. When it’s slightly unscrewed it isn’t, even if the threads were bare aluminum, the negative part of the battery is touching the spring and pcb it’s connected to, nothing else. So it needs to be energized, i.e. have potential, for this to work. I mean I don’t think there’s really anything in the tail spring to go wrong or act anomalously. I don’t know but it’s really freaky doing the two person thing and lighting it up upon touching someone else’s hand.
-Zach
chadvone
chadvone's picture
just watched the video. You should sell that broken D4 to me..
Lexel
Lexel's picture
read my post and think about it
even with unscrewed tail cap you touching the bare battery bottom it will light up
ZED
ZED's picture
Sorry lexel I was respondeing to moderator007. That makes sense and without the knowledge of specifics is kind of what I was thinking. I bet you my ground (black) wire is touching the MCPCB. cause for alarm or is it fine?
-Zach
