Thanks Henrik. I believe there is some market for small LiFePO4 cranking batteries. However, I wonder how much actual lifespan can be expected from a LiFePO4 battery in this regard. I mean, without some sort of adjustment modification to the vehicle (motorbike) voltage regulator.
Recently a friend of mine visited me with an old store bought small bike LiFePO4 battery. We carefully dissected the box with my rotary tool and found a set of 4x prismatic cells inside, they weren't looking very good and some were leaking a bit. A balance board was also inside, but after testing with my power supply unit I found none of the balance stages would activate with less than 3.7+V. In my opinion this is a joke because at that point the battery is more than probably receiving substantial damage. Yes, I am battery care picky.
I kept the box just in case I decide to custom build some battery.
HKJ, it would be useful if you removed wraps and showed us the codes on the batteries that you test, so we can check if the cells we’re getting are the same as the ones we’ve seen in your test.
The stated characteristics look good, but do not correspond to reality, since the capacity of these batteries is not 6500, but 5000mAh. In this case, we do not know at what discharge current these elements passed the test. I suspect that this was a low current, so if you take a high current, then the capacity of these LiitoKala will be even lower. Here there is one buyer who informed us about this in his recall - VariCore LiitoKala 6,5Ah
Volumetrically speaking a 32700 cell is (32² × 70) ÷ (26² × 65) = ≈1.6313 times a 26650. Thus, nearly 5Ah for a 32700 LiFePO4 can be considered a good result. Look, for example, at any of these reviews:
A discharge test of that 32700 LiFePO4 should still be done to see what it can handle. Hope its 35A continuous current rating is true.
It is annoying when any of you post localized AliExpress links (ru, es or whatever) because stupid AliExpress sets a cookie for that locale, forcing global english site users to click on “go to global site” and also needing to fix the link by at least changing its prefix. It would be good if you were to edit your links to make them international. A global english link works for everyone.
Unfortunately, I don’t know how to take a picture of a text from another place, and then here to show this picture I took. But, this would hardly have helped for two reasons. First, the buyer from Russia and its text in Russian, which you do not know. Secondly, the text of this person contains a lot of grammatical errors, because of which even the most successful translator of languages would not help you. Therefore, the only way out would be if I corrected the mistakes made by him in Russian, and then gave you a translation into the international language. However, then you can say that this is not the original and we are not sure that we trust this experience. In addition, I myself am also too lazy to perform such transfers, but if you do not believe the experience of that person, then no one will be offended for it. Therefore, in such cases, they say that ‘if someone does not want to learn from the mistakes of others, then he will learn from his mistakes.’
I saw some NOR test pics on AliExpress and they were over 6000mAh, but now i’m not sure anymore if i remember it correctly…
Many sellers have these big fat cells, but maybe there are different types being sold with that grey wrapper.
Who knows?
Either way, they seem nice for a 3D Maglite.
It would be good enough for me if they did 20 Amperes without too much sag.
I agree about the AE links.
If possible, please use the English language address.
Another thing, i hate when people use the advanced post editor…
It’s really a mess with code cluttering the text when you quote someone…
Oh well…
Only 200mAh
VTC5A is a 2600mAh Typical Capacity Cell
VTC5D is a 2800mAh Typical Capacity Cell (Designed for Dyson, with some technological improvements over the VTC5A)
“акб пришли быстро, это радует. Но у одного немного повреждена термическая оболочка, это расстроило , но не критично. Термическая оболочка и кольца со стороны “плюс” коряво натянуты , так что могу предположить, что это подделка, но только после всех проверок и тестов. Проверить сейчас не могу на ёмкость и отдачу тока, так как ещё жду imax b6. пришли заряженными до 3,2v. Буду изучать этот продукт и оставлю отзыв позже.
09 Dec 2018 23:57
Дополненные отзывы Ёмкость оказалась чуть меньше 5000 mA/h. Покупать 2 штуки бессмысленно. Минимум 5 штук, так как моё балансирующее устройство идёт для 5 акб 100А. Придётся еще 3 покупать.”
translation from Russian into English:
“Akb came quickly, it pleases. But one had a slightly damaged thermal envelope, which was frustrating, but not critical. The thermal shell and rings on the plus side are clumsily stretched, so I can assume that this is a fake, but only after all the checks and tests. I cannot check now for the capacity and return of current, as I am still waiting for imax b6. Came charged up to 3.2v. I will study this product and leave a review later.
09 Dec 2018 23:57
Augmented Reviews Capacity was slightly less than 5000 mA / h. Buying 2 pieces is pointless. At least 5 pieces, as my balancing device goes for 5 Akb 100A. 3 more to buy.”
I always use the advanced post editor. The simple post editor cannot cope with web addresses consisting of special characters (like the ones at Henrik's site).
Since the advanced post editor can do nearly everything the simple does and much more, if I were sb56637 I'd unify the editor engine so only two choices would be seen in the drop down below: post editor and plain text.
The unified engine should be based in the advanced editor plus the good stuff missing from the simple one (like image width fit to screen, a working insert emoticon window, etc).
Yes, maybe most of you would cry for a little while but this is normal for newborns. ;-)
I got 1/2 dozen, been available for least a few months, thought sold in a lot of places under the Vapcell wrapper, but they advertise them as VTC5D. They are right up there with the 25S - my tests get about the same performance, better than a VTC5A, least for me.
