I’d bet that the difference in output has something to do with the CW to NW tint showing up differently on camera. Inside in the dining room, the E07 looked brighter, but the outside shots not so much.
Thanks for making the video, especially going through the UI and programming.
You cant? Anduril allows control of the AUX LED’s (choose between L, H and none), are the switch LED’s hardwired or something so the Tiny85 doesnt have control?
The Anduril version is different between Fireflies lights and Emisar lights it seems. On my D4S, I can switch the aux leds between low, high, beacon, but it doesn’t have things like muggle mode. On fireflies, it has muggle mode, but can’t switch the aux leds.
The problem with the instruction manual is that it’s printed in black and white, ToyKeeper laid it out in color. So the two thin lines indicating one click or two clicks are different colors and much more easily understood.
Nice video, fun to watch as usual… wish you’d gotten a color manual so it would have been easier to follow. Learn the actions first, everything after that is easy.
The lights in the switch are Fireflies behaviour, not inherent to Anduril. They decided 2 of the smd’s needed to be on at all times, the other two work with the aux smd’s. Not how TK would have done it, but how Jack wanted it.
Yes, according to multiple controlled tests the E07 powered by the 21700 cell is nearly as powerful. If I had a set of 3 sony VTC6 I think there would be a gain on that. My LG cells are descent performers though.
Thank you for letting us know.
I was thinking that I read somewhere the E07 auxiliary lights can be turned up or down (maybe off) using those pots that sit on the board? Perhaps one of them is keyed to the switch? It is possible to turn off the LEDs on the face by 7 clicks from off. On/blink/off etc
Nice job on the review, very well explained! if we’d have had yours and m4d max’s combined that would be the complete review lol! the point about not many batteries fitting in the actual lights (length wise) in the other review is quite important, especially if buying them at the same time - nothing worse than a shiny new light and battery turning up only to find they wont’t fit lol!
I’m still not convinced about the headband though, it’s more of a quick fix than a proper solution - the fact remains it’s still the wrong headband, the clip just stops it wobbling a bit.
On the thermal configuration example. He did 9 clicks, then 40 clicks. What does each signify?
He said 30 clicks would give 60 C… He actually did 40 clicks which would be 70C or 158F. Is that too hot of a ceiling?
That’s Anduril only correct? I have a couple that are older Narsil M. Is the procedure different?
Is the 21700 battery length issue on the E07 only limited to the Nichia 219 versions? i.e. Should I be concerned with 21700 battery length on the E07 SST-20 version?
