Thanks Pete…. I was playing around with it before I read your post and I got it to work although I am not sure if it is safe.
I re-enabled Stylish and exported the BLF info, then imported that into Stylus and disabled Stylish again …. I checked and it is working like it used to BUT is that okay or is some of that code vulnerable?
Edit: After doing the above and reading your post I went to the http://budgetlightforum.com/comment/1358466/edit link you provided and clicked the link ‘Install style as userscript’ ………. would that have overwritten the other script? Sorry for the confusion…. CTE makes my brain disfunctional! :weary: :weary: :weary:
TK, is userstyles.org having collywobbles lately? I can’t get in, haven’t gotten a password reset, and get a beachball cursor trying to search for “BLF”
There’s recent interest in this from people who saw me mention using it to eschew tedious signatures, and I’m just as confused as the next user about how to revive my old Stylish script. I did see mention of how to convert, I”ve got to go read that.
I did get Stylus extension to install in my Firefox (Mac, 10.12.6)
Ive installed Stylus on Firefox Mac (thanks hank!) and have used code from ToyKeeper (thanks!) to hide all signatures on BLF
the app is here
the code is this:
.forum-post-content > div.clear { display: none; }
and figured out how to Completely Hide posts by any member, with the following code:
I’m not really sure what’s up with userstyles.org lately. I checked it just now though, and it appears to be working normally. I did a search for “blf” and it returned several results including both of mine.
About hiding posts, it only needs one line per user. There’s no need to repeat the same UID more than once and if it’s only one person then only the last line is needed. The lines before that, ending in a comma, are optional in case people want to hide more than one person.
Or, instead of hiding people, it can be used to style posts on a per-person basis. For example, sb’s posts are usually important so I have those styled with a green banner and a bigger brighter font to make sure I’ll notice.
I haven’t looked into styling thread titles in the list, but it likely would need selectors based on text content instead of class or ID or anything like that… so it may require really recent CSS features or javascript.
It’s typically a lot easier to do this with an ad blocker plugin. Some have the ability to right-click on the thing you want to remove, select “hide this”, and then drag a slider to select exactly how much to remove. Same effect, but it only takes a few seconds.
thanks
I used adblocker to determine the .JawboneContainer label to use in Stylus, to hide the opening banner on Netflix…
have not learned how to use adblocker to block that particular animaterd banner element on Netflix
I do have all the banner ads on a couple websites blocked, thanks to adblock right clicks… but for some reason, it was not that easy with netflix, so I had to use Stylus
I dont have a good understanding of the apps…
and
the netflix style I posted has an unintended consequence,
I lost the ability to see individual previews that I actually want to see…
thanks for the intro to stylus
ive not even scratched the surface, but so far so good
If you don’t see any problems on your end though, there shouldn’t be any need to update. I updated it because the subscription page had sad faces all over from a broken tinypic link.
Is it fixed? Im still seeing something weird on the ‘title/author/last comment/unsubscribe’ header. Im not seeing full sad faces…… just the yellow tops of their heads….Do I need to update something?
