I guess Iām going to have to buy one of these after all to carry my beautiful Hoop copper pill. Yāall are gonna have to explain to my wife, Iām tired of fighting itā¦
No patina? Boo
I donāt like coated copperā¦.
Got my copper S2+ today, had completely forgotten ordering it! Beautiful light, nice work Simon!
uncoat it with acetone or something,ā¦.
I edc this light at work, SMO and OPā¦.
SO nice
can u only get this in xml2 or xpl emitters ? and ali sucksā¦ still waiting for another light from nov27 boughtā¦ not tempted buying from there again useless shipping options compared to banggoodā¦
No, you can get this in Nichia 219C 4000/5700k 90CRI now
18350 tube lets go
Was just about to post that. Itās good stuff.
not under 3000k tint ?
can you swapp heads with a alu s2+ ?
I could swap the Cu body with an alu body, so I assume you can swap heads with an alu S2+.
That is a wish, right? The 18350 tube is not available (yet), is it?
With shorty tube I would consider this Cu version
Why donāt yāall send Simon a note and ask him to have the Copper 18350 tube made, if he hasnāt already chosen to do so he might re-consider itā¦
I asked once, he said no plans for 18350 tube since it is not high demand for such thing,
Humā¦maybe we can try again?
If the members that already have a Cu S2+ (and want orā¦need :smiling_imp: a shorty tube) & the ones that donāt have one, are interested in shorty tubes, maybe we can check with Simon again if heāll manage to do them!
It would be neat to have male/male joining sleeves (the sleeve would be female on each end) in copper to connect multiple 18350 tubes together for use with, say, a 6V emitter such as the 50.2 or 70.2 or MT-G2, even 3 tubes for a 9V MT-G2. A fourth tube for a 50.2 quad in 2S2P for 12V operation from 4 cellsā¦ the options are very broad. The sleeves would act as grip along the length of the tube.
short tube needs a good saw, some sanding plane then solder with very little paste both pieces together
if the coating does not get damaged the result may look good enough or need some sort of mild sand blasting or so to hide the solder connection
Lexel taking a jewelers approach to resizing
i can produce some ,but i want to remove the knurning or change the style .
Product yield rate can be improved greatly if i dont process knurning
similar to sleeve of L4 flashlight ,right?
