ENERGIZER Ultimate Lithium "NO LEAK" Guarantee - mine leaked! What's your take?
Don’t know if this will help or not.
Thanks, but I already posted that link in the op.
I have sent them emails with photos…my remote doesn’t work anymore, the air-con’s main unit only has the manual, mechanical ON-OFF switch, no modes, etc.
Oops sorry, didn’t see you posted the link. Looks like they will only replace the batteries, not the damaged unit. Kind of shady with their “guaranteed not to leak campaign”
Hopefully you can get a replacement remote. I have a 5 yr old LG TV, where the smart functions can only be used with the “LG magic remote”. Cost me $50 for a new remote. Guess what brand TV I won’t buy again?
Energizer has replied to my emails with photos and asked for some details, etc.
Let’s see how they will honor their ‘No Leak’ guarantee on their Ultimate Lithium Energizers.
Hope you had a positive experience with Energizer tatasal!
See my response to this over in clemence’ thread.
A LINK would have been nice. So I put it in for you, I hope you don’t mind.
All my AAA lights are on Energizer for a reason. That reason is they are not Alkaleaks.
Thanks Henk4U2, I had been searching for that with no luck. . :+1:
I’ve also had the Energizer Lithium primaries completely discharge in just a few weeks from installing them in torch.
No parasitic drain was responsible for this. Had it happen twice on two different torches.
Needless to say, my confidence in Energizer lithium primaries is not very good. To be fair, it happened to only two batteries out of the 12 that I had.
Also discussed in CPF, of which I also posted there: http://www.candlepowerforums.com/vb/showthread.php?454399-L91-failure-rate-fragility
Sorry about that and thank you Henk!
Watching this closely. Thanks for posting, and I hope Energizer comes through.
I wonder where their batteries are made ….
As an experiment I tried posting a link to this thread on Energizer’s Facebook page.
Their managers “will review” the post — it will be interesting to see if they allow it to appear.
Possibly they got a bad batch from a subcontractor. Time will tell.
To anyone reporting similar instances, can you please include either the build date or expiration date of the cells you had troubles with.
I use L91’s in a very expensive piece of equipment ($900+) and would like to avoid having to test out that guarantee myself…
Build date is a 4 digit code stamped in the case near the negative end (not printed like the labeling / expiration date) but easy to read when viewed at an angle.
Isn’t that “03-2033” the date of expiry?
Yes. I was asking about the other couple guys mentioning they also suffered failures.
Just trying to make sure I’m not using cells from possibly known-bad batches.
Mine was made in Singapore, bought in the USA by my brother in blister packs of 4.
I’ve seen a lot of situations where the + end of a cell and the spring touching it became corroded. Often enough corrosion goes right into the case along the + wire to the circuit board.
I’ve noticed that happening on all sorts of things — flashlights less often than little radios and electronic thermometers/humidity meters/clocks/calendars, for example.
I’ve wondered if this isn’t because some current was flowing even with the device switched off.
It’s one of the reasons I’ve consistently used Energizer lithium primaries on anything I valued.
i run energizer lithium primaries inside all my backup/emergency and bugout system, out of several devices like double or single AA flashlights, beacon light, M26 taser that runs on 4xAA and baofeng two way radio with 6xAAA adapter cases and lastly emergency ceiling lights/bunker lights that runs on AA or AAA batteries
im not sure how this happened but it was found in one of those devices since i run a test and check on them each month, luckily i discovered it before it would further cause damage to my device
out of every hundred you’re gonna expect a few failures i suppose, yet i cant rely on eneloop due to my higher powered devices requirement(especially baofeng and taser) eneloop tends to discharge itself down to nothing after at least 3 years so some of us will surely stuck with the imperfect lithium primaries which energizer or NICE brand produce
What about USB rechargeable AA batteries with a Li-ion battery and buck converter to 1.5 V inside, like the Fenix ARB-L14-1600U?
If this helps :
I live in Spain. I have been researching a bit…
Here at home… I have 3 types of energizer batts:
1- Energizer Lithium (silver label)
2- Energizer Alkaline (they are the standard alkaline, black label)
3- Energizer EcoAdvanced (they are new alkaline type, silver label)
The energizer Lithium, are made in Singapore. They have “vent holes” in the + pole.
The energizer Standard alkaline, are made in Singapore. I can not see “vent holes”.
The energizer EcoAdvanced alkaline, are made in USA. They have “vent holes” in the - pole.
The ones made in USA seems the be better built than the ones made in singapore.
I can see more variants of energizer alkalines at the stores. Will check them. But I can not find a “no leak guarantee” variant here.
None of my energizer lithiums have leaked or died in any way. (But I had the ones from fasttech branded as “nice” that were at ZERO volts after 1 month without being used…. only used a few minutes in a flashlight…weird…)
I have had a few energizer alkalines leaked… but other brands leaked even more…
