The SIR800DP has been around a while - Richard at MtnE has been selling them - it's a very good FET, stays cool under high amps. I thought it was pretty much in agreement the SIR404DP was superior, next step up, then is the SIRA20DP which I currently use as one of my two choices. The other is the Infineon BSC009NE2LS5ATMA. I usually use the Infineon now - great specs. I believe others have had problems with the SIRA20DP.
Thanks both of you for the info. I shall report back soon.
I wonder is SIR882DP new version of SIR800DP.(updates:looks like they are for different range)
I would take my multimeter and measure the resistance on U3 from the big pad to one of the three smaller pads. Compare the 2 drivers. I think you already did this. 4 and 6 million ohms is pretty much infinite resistance, so I don’t think that is a problem.
I think you can do the same thing for U4 measuring the pad on the left and bottom.
You sure? He used a capital M instead of a lowercase m. The miliOhms range is like a dead short.
I have a 3v 3 channel TA driver here. I tried to measure across the FET and got 1K ohm. Across ch 2 I get inconsistent readings. Across the single 7135 I got 4.5k 1k ohms. (Had to break our my new Probe Master test leads. DMM is still crap, though. Lol)
I don’t have suitable FET for it. I have only a replacement driver sent by Haikelite.
Before I install this new driver into the light, I wish to investigate how to repair the problematic driver.
Being busy at work that I can’t troubleshoot it yet.
I troubleshoot it and can’t find any fault on voltage. There is no voltage that can turn on U2 and U4. U1 has proper 5v power. There are difference below.
1.Voltage between LED+ and LED-
Problematic driver has 410mV while replacement driver has 320mV.
2.Resistance between LED- and ground
Problematic driver has 51Mohm while replacement driver has 68Mohm. I think my previous resistance measurement done a few days ago was wrong on decimal point.
Both drivers have similar current consumption, boot up with 6.8mA and then to 7.3mA and then to 56.5uA. This is without LED connected.
The FET is supposed to be the SIR800 posted before, this is what I used in the drivers I hand made and have not heard of any issues with the 100+ that are floating around.
The production drivers though have used fake FET’s in at least a few of them, it was supposed to be corrected but no idea if it ever was.
The fake FET’s are most assuredly a problem and not up to the task of this light for extended use.
Without specialized equipment it can be very hard to test an FET properly. It is generally easier to just swap it out and see if that fixes the problem. This is the first thing I would try personally, for the $1-3 it would save a lot of time in the long run.
The other option is the small FET for the 1st channel could be an issue as well but far less likely since it sees a max ~0.5A.
I have taken out the FET with hot-air and solder the board back to the light with just LED+ and LED-, the leakage is not seen. It blinks two times when batteries make contact and then no visible leakage. I was happy for a short moment.
And then I put the replacement driver into the light by soldering all the five wires, the leakage is still there. Looks like replacement driver is not good either. Light function well, just it has this annoying light leakage during off.
Oh boy, not sure, but thought I seen someone post that some of the LED's may be the cause but I would think you would see it only that LED or LED(s), not all the LED's? Shame because I don't think I've seen this problem in my limited # of lights with this kind of driver and power.
So you didn’t have the switch wires connected at this point?
This reminds me of the time I modded my S70S and did a custom blue switch led powered from a positive source on the driver. I noticed the main xhp70 led was glowing faintly. It turned out that the switch led was allowing a bit too much current to flow through the driver. I then had to run the switch led power wire to a source before the main led. That fixed it.
Anyway, you might try disconnecting the switch led and see what happens. I kind of doubt that’s the problem since we would see all the new MT09R with glowing 70.2. It doesn’t hurt to try it, though.
