The 20S review is up.
Molicel INR18650-P26A 2600mAh - 35A - 18650 - Li-ion - Rechargeable batteries...
That was fast! Thanx!
Edit: Yes, very close, slightly better than the Vapcell 2000 black. Discharge curves align well.
I have just recieved two of these 32650 LiFePO4 cells: https://nl.aliexpress.com/item/32650-3-2-v-7000-mah-lifepo4-oplaadbare-batterij-mobiele-LiFePO4-5C-ontlading-batterij-voor-Backup/32878468860.html?spm=a2g0z.10010108.1000013.5.3d9e7580Cyry4Y&pvid=c5572a18-c89d-440b-a640-9a2bed6460af&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.90158.0&scm-url=1007.13339.90158.0&scm_id=1007.13339.90158.0
Tested with a HTRC B6V2 Balance charger at 2A discharge current they are about 6500mAh.
These will be used to replace a 6V / 4Ah lead-acid battery in a solar powered light (as soon as i get the 2S balance boards https://nl.aliexpress.com/item/2S-8A-Li-ion-7-4v-8-4V-18650-BMS-PCM-15A-Peak-current-battery/32800676048.html?spm=a2g0z.10010108.1000013.3.3e367ecfk06lou&pvid=fbbf3d65-a32c-4bf2-8991-8767aa669f45&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.90158.0&scm-url=1007.13339.90158.0&scm_id=1007.13339.90158.0 )
Dank u. :+1:
But that protection board doesn’t balance charge, i think…
Weltool ub-123a
3.0v micro-usb
Inr 16320 2.25wh
Newbie here and hello to all….
I have a collection of NiMh and for the price and availability, Ikea batteries are pretty good.
Henrik, did the EAIEP cells arrived? Just curious, I know super cheap shipping can be super slow but, by this time, they should be at home. :???:
Welcome newbie. This thread is for battery review requests for HJK but in time you will figure where to post what. Again, welcome to BLF!
Yes, but I have not tested them yet.
Can you do review of this usb rechargeable?
Thankk.
It makes it easier to find it when the request includes a link where I can buy it (Remember I am in Europe, this means mostly from Europe and part of Asia).
Sorry man. It’s not for sale until February. Taobao is supposed to have it. I just wanted a rechargeable 123a that puts out just 3 volts.
… I just wanted a rechargeable 123a that puts out just 3 volts.
16340 LiFePO4 cells.
peabody:… I just wanted a rechargeable 123a that puts out just 3 volts.
Thanks dude. You have to buy a separate charger though. Guess I’ll just go with throwaway cr123a’s for now.
Barkuti:16340 LiFePO4 cells.
Thanks dude. You have to buy a separate charger though. Guess I'll just go with throwaway cr123a's for now.
Not really a problem, there are inexpensive and good chargers which can cope with LiFePO4 cells. As most notable examples the LiitoKala Lii-202 and Lii-100. This is not for sloppy users, to charge LiFePO4 cells you will have to press the MODE button to swap charging mode to Li-Fe upon cell insertion. A very easy thing to perform once accustomed.
Choosing this path will make you save money sooner or later; quite soon I'd say given the price :facepalm: of CR123A non-rechargeable lithium cells.
Cheers ^:)
Molicel P26A 18650?
I also searched for a European source for the 4000mAh 21700 Molicel P42A but could not find one.
Molicel P26A 18650?
Molicel INR18650-P26A 2600mAh - 35A - 18650 - Li-ion - Rechargeable batteries | NKON
I have 3 Molicel in queue, the P26A will probably be published this month.
Here : Molicel P42A 21700 | Fogstar | Official UK Molicel Distributor
In Great Britain, a little expensive, but the only one and NPE approved so Grade A Cells guaranted.
Here : https://www.fogstar.co.uk/products/molicel-p42a
And Fogstar.UK has the same batch of Molicel P42A than Li-ion Wholesale visibly, look at her pictures!
HKJ, I want to thank and compliment you on the new filter functionality on your site.
Helps lot in my searches!
