6. Batch "TA" 1S or 2S Bistro HD OTSM/NarsilM drivers 15-47.5mm size fit, S2+, C8, H03, MF01, MT03, Q8 Clicky or E-switch
is it possible to make a FET+N+1 driver for a 2s2p configuration on a MF02S?
does not make sense, as the LED is 12V, it woulsd smoky any AMCs plus its not regulated
Buck driver with 4S carrier mod is the way to go, we got full output and regulation
Ahhh, the custom X6R driver exists - I've used them recently.
This is a triple stack from PD68, old but latest driver design. All my pics on this triple LED X6R mod here: photobucket.com EagleEyeX6R Triple
It's a great light now - triple 90 CRI XP-L2's, though I didn't get in an AUX LED - need to add that still.
Hi Lexel, could you build me a
DD+7135 for 2S/2P and XHP70.2 for my MT70?
Hi as I mentioned before the MT70 uses a 12V LED board, so you cant DD it from 2S/2P same with buck driver
the Carrier mod is needed in any case
I could build a modded AMC board with DD FET + small FET with resistor 2 channel, but rather prefer regulated Buck driver for it
This is the standard solution if you dont want to change LED board to 6V which on the other hand would mean limited current capabilities with buck as voltage is reduced
Sorry to hear about your shipping troubles Lexel. You do great work, please keep us updated if you come up with a better solution. I’ll still be buying from you even with the higher shipping. Totally worth it.
Shipping is still possible, but for bulkier better use new Item letter which got more expensive
Seems I can use international with 5 per quarter and no limit for my country but then its also more expensive than last year
So 3.8€ for >10mm untracked
6.8€
Oficially items are banned from. Ormal letters but I dont think flat drivers will cause issues as they can be handled by sorting machines
Is there any reasonable option for expedited shipping to US?
I could send DHL Express for about 40€
Well that covers all but one word of my question. Lol. Plan ahead I guess.
Strange that packages from Russia and Croatia come several days sooner then Germany. From a geographic perspective anyways.
Both of my orders have been shorter then I expected.
While I here,
Lexel. If I want to remove some 7135’s from a Skilhunt driver what order??
what do you mean with shorter order, did I miss some parts?
AMCs get the best removed with hot air, or 2 other persons with 2 more soldering irons, guess whats easier,
but with hot air you have to be careful not removing other parts as well including the other side
Lexel, Shipping was shorter(faster) then I expected it to be. I should of said shipping was faster then I expected. You beat orders from China ordered at same time.
Thank You for providing these drivers.
On skilhunt driver I want to remove some 7135s without removing the single channel 7135. I know where the single channel is on the modded drivers you sent. I need to know if the single channel 7135 is in the same place.
just installed in my Q8 a driver from Lexel, great quality and max 7135x15 regulated brightness, also running with anduril!
I also wanted to thank Lexel for all his help when installing the driver!
the usual 21mm for H03 has the single on always on top side
the ones with on down side originate from C8F 21700 design and have it always in that position, but other sizes can be differnt
Any chance you could flash a version Anduril instead of NarsilM?
Its no problem to flash Anduril or Emisar Firmware as the drivers are compatible
Maybe I should have asked “can you sell them already flashed with Anduril or Emisar D4S?” to avoid confusion.
If you can I’d like to order 2x 17mm drivers with Anduril.
Thanks Richard.
hello, am i able to order a 30mm driver for an Convoy L6?
Yes, Lexel will send you a personal message asking you what options you want.
