Fireflies E07 preview
@FireFlies, I have a question.
My E07 makes a clicking sound sometimes…
First heard it after deactivating the Aux LEDs
Heard another click when I run turbo for a few seconds, then another one after ramping down
Heard another click while light was off and in standby and lying next to me.
Why is that? Why does it make a sound? Is something broken? I got the light today, like one hour ago.
Looks like the shelf isn’t perfectly flat. There is contact on the edges of the MCPCB but not in the middle.
I seem to have an underperforming light . I bought 2 . One is an XLP 6500k . The other is an SST20 5000k. The XPL will hit 6800 lms at turn on . ( TA meter ) The SST will only reach around 1500 at turn on with fresh charged 40T . I have cleaned all connections , tried different batteries , It drops very quickly 2 seconds after turn on . Down to like 500 lms.
I have not checked thermal configuration . After seeing DB’s post of no thermal paste , I am not sure what the safe , maximum temp I can set it at . Also , does this seem like it may be the the cause of this lights problems ? ( thermal config )
I so want one of these, on the other hand, I so don’t! Maybe in 6 months time…… nearly all the feedback on Fireflies lights seems to be 50/50 on quality/problems etc. Still this can only mean better things to come. :slight_smile:
I don’t need a flashlight but want one :slight_smile:
Personally I’m going to wait* for a review with runtimes/effiency.
*=Unless someone posts a good discount code, then I may change my mind :slight_smile:
Thank you Jack, yes I do understand all that… the thing is though the MCPCB has hard square edges on the bottom of the board and is made to fit very exactly into the head of the light. On the other hand, the light has rounded edges where the walls meet the emitter shelf. This prevents the MCPCB from sitting down onto the emitter shelf and making good firm contact. With such a thin film of thermal paste applied to the emitter shelf, nothing touches the MCPCB. Heat is forced to travel into the mass of the head through the extremely small contact points where the corners meet. Not ideal at all.
The fix is a simple bevel of the MCPCB, so it can sit all the way down onto the Aluminum shelf. OR, a slight reduction in the overall diameter of the MCPCB. OR, a square cut between the shelf and walls of the head. It’s really such a very small bit of contact blocking correct fitment. The copper MCPCB is thick and robust, well done on that, and also why the light still works as is. :wink:
My E07 Nichia also has this problem (Worried that the light glass is bursting…), it seems to happen in high brightness,
This one also has the broken off leg on the optic。 :person_facepalming: :cry:
You can try to turn the top metal pressure ring away. Remove the TRI lens and adjust it to the installation.
My E07 SST20 has no broken feet, but the TRI lens has a distinct bubble. :cry: :cry: :cry:
Just a minor difference, such as night and day for example!
My XPL HI E07 also makes an occasional clicking sound. This happened a lot more when I first got the light. With time, this seems to have diminished. Maybe the sound is air under the star heating up?
In any event, it does not seem to affect performance in any way. My EO7 performs great.
What is the suggested battery for an XPL HI 4000K E07?
What the end goal, runtime or max output?
Max output: 30T
Max runtime: 50E
Then logic tells us the 40T would be a great compromise between the two extremes…
How much output is lost between 30T vs 40T? I do have a 50E but don’t have the light yet.
I asked on the E07vn CPF thread and am awaiting a response.
I think that I remember him saying that he was awaiting his 30t’s to come in. He may not answer until they do.
What is the average lead time of the EO7 actually being shipped / posted.
I have a 40T and 30T on
The way, I let you know Friday hopefully
Sounds good. Enjoyed your video review.
You probably lose about 10% output but at some point when the battery is less than fully charged the 40T should pull ahead. Probably after about 1000mAh the 40T will start to be better.
Flashaholics, test see if you can take a reading every 15s for a full minute or something or possibly do 30s bursts in intervals and do like 4-5 of them. Should be interesting to see how things progress.
Note to the assembly team at Fireflies. Thermal paste is very important. My SST-20’s went blue in about 20 seconds on a 30T cell… gee, wonder why…
dumb question here, but can someone please tell me what ‘went blue’ means. Does that mean kaput? Because in a later post I think I read that Dale indicated his light still works?
thanks.
and regarding Fireflies comment on cells, am I ok running my SST-20 on a 30Q cell without harming anything. Don’t want to ruin this nice light :slight_smile:
Reset thermal to 60c. Still only hit 1400 lms and immediate drop to 500. Jack says it should hit 2300 high , 4800 turbo. (SST20 5000k ) Cleaned every thing checked everything I know to do . Anyone have a suggestion ?
(1) Double-check to make sure you aren’t in Muggle Mode (6 clicks).
(2) Remove star, bevel bottom edges of star, reinsert star with fresh thermal paste.
