FREEME ✌ ASTROLUX FT03S SFH55 9300lm & FT03 SFT40 2200lm 1300m NarsilM v1.3 USB-C - ALIVE
Yes please. I am in for one.
Can anyone recommend suitable 26650 cells for this (will be my first 26650-powered flashlight)? The Shockli 26650 IMR 5500mAh seem to be highly rated, but their product page at Mountain Electronics lists the diamer as 26.7mm and states ‘These are a larger diameter than most 26650 cells! PLEASE CHECK MAXIMUM BATTERY DIAMETER OF YOUR DEVICE BEFORE PURCHASING!’ Don’t want to get them and then find they won’t fit…
@freeme are you able to confirm the internal diameter of the FT03?
I think you need to lower the output or increase resistance for SST20. For multi led lughts no problem because the battery sag helps them survive. But in a single led setup I killed 4-5 SST20 leds with fet driver.
Freeme if I’m in for 3 lights can I use thecoupon I get 3 times for 3 separate orders? That way every single light will be under vat price level. But 3 lights will go under customs and need to pay vat.
I missed this one.
Might be really interesting I’m IN :slight_smile:
Has anyone received a code yet?
Really wish the SST-40 had some warmer tints available.
Just poking around….the product is showing on Banggood…but it’s status as far as location/warehouse is “DESIGN”. So…appears to still be in initial stages…but getting close. Guessing codes won’t be available until it shows “CN” warehouse…or vice versa.
Their Chinese New Year holiday will start this weekend. Most likely have to wait till both BG and manufacturer resume work.
Banggood has a option for CW and NW but I thought the SST-40 was only available in 6500k?
Interested
maybe nw is xp-l2
If you check the datasheet they come in 4500k-10,000k. The limiting factor to us hobboests is what a retailer sells and only CW have been for sale up till now. Astrolux could have ordered a full reel at which point they could spec a tint bin of their choice.
So, we’re not getting an SST-20 for the light, huh?
Well that would’ve been nice for 1000m+ of throw.
Interested!
You can put osram CSLPM1.TG – 2mm2 and it will run with FET driver.
Should throw further due to smaller led.
CSLNM1.TG throws even better but fet driver is too much for both and turn them angry blue.
5000k here : https://www.mouser.fr/Search/Refine?Keyword=sst-40
Question for the under-educated;
How is Astrolux getting 2400 lumen from a SST40 emitter? How many amps/watts to the LED?
Has anyone seen CD numbers? Tested one of these?
@wstrachan
1. They aren’t getting anywhere near 2400 lumens. Even when heavily overdriven, 2400 lumens is the best case scenario at turn on with a full very high drain cell, and without counting optical loss, and temperature increase of the LED.
2. Candela/throw numbers seems a bit high for a domed SST-40 light, even massively overdriven.
In Convoy L2 which has about 5mm smaller head:
SST-40 N4 BA 9.5A 2226 lumens 172400 cd 830,4 m
Maybe the cd reading can be real because of bigger head but the 2400 lumens not. Maybe 2100-2200. I used 18 AWG wires in that L2 and all springs bypassed.
Thanks. At times Astrolux numbers are inflated but in many cases they are accurate so I was wondering if anyone knew.
