ENEDED
Did you apply power to the source and drain when you measured? I hear you need to do that in order to get a true resistance reading.
No voltage applied. I meant i measured Rdsoff, not Rdson.
Yep, just as I suspected. They did indeed use fake FET’s against my will and recommendations.
In their defense though they are apparently overflowing on china supplier shelves. Every driver I have worked on in china so far has ended up with a fake FET on the first prototype. Which is why I insist on prototypes being tested by me. HL never sent me a driver to test so I was not able to test it in person.
Now standby current is stable. It’s about 58uA blue led off and 166uA blue led on.
Are you sure Haikelite knew they were buying imitation units or maybe their supplier said they were real and then sent them fakes.
Ya, too bad HL is not investing more time and money into getting real FET. It could have saved them and their customers from troubles. Based on quantity they buy they can get quite low price per FET. I don’t understand what’s their logic.
I don’t think they knew they were fake when they ordered them but I did tell them to be on the look out and send me a sample to check which is what they didn’t do.
It was not a malicious use of fake components by any means, they just skipped out on the final step that would of prevented it.
I am not going to get into a lot of detail but lets just say there are 2 fractions in the HL upper management. 1 side is good and I support today, the other is classic china business practice that leads to issues like this.
Hey TA!
I was just reading all these recent posts with some concern. I just received last week an MT03 TA. If mine has a fake FET driver is there an easy way for me to identify that?
When you say that the fake FET’s are not suitable for extended use it makes me concerned this light will fail shortly after whatever the warranty period is given that it’s not going to be a daily use light.
I’m light years behind you guys in technical understanding and mechanical skill but I’m familiar with working with electricity. I’ve never worked on small circuitry before but don’t want my recent investment and so far favorable purchase to be for not
It seems like the majority of fake FETs are doing their job. Problem signs are if the main leds stay on or if you increase the current through the FET by adding bypasses to the springs. Too much current could make the FET fail completely.
I imagine all these factory drivers have the cheaper FETs. Yours included.
Maybe DENGOH can hold the old FET next to the new one to photo the difference.
Yeah, in most cases the FET will be ok as long as you do not modify the light. Not ideal but ok.
Luckily the ones that do fail are only a $2 replacement FET to fix them. Although that assumes you can install it, but usually you can find a repair shop that can do it for a few bucks worst case.
If you fully charge up the highest drain batteries you have and disable the thermal protection then let it run until the light is ~80-90C it should be a good stress test to see if the FET will fail. If it survives that it is unlikely it will die from normal use.
You should reset the thermal protection after this of course.
Thank you for the suggestion.
I’ll run the thermal test tonight. I have an IR thermometer and I’ll be using fully charged 30Q’s so it sounds like I have all the right materials to complete the test.
I almost just bought one. Understanding the concern and how to mitigate and test for it, from my perspective it’s off my list until the next version is out and gets tested. Haikelite needs to be deliberately careful after all the potential customers they lost already with other bungles, ignorance is not an excuse any longer.
Haikelite must put assembled light into a dark box to detect this faint light leakage. Their operator will miss it in a bright room.
I think the fake has big dot at the bottom left. Who has real Vishay SIR800 and care to share pictures?
These two Haikelite SIR800 giving me trouble right from start without extended use. Notice the dot is big. And I have to really adjust my phone camera angle in order to get clear picture on the printing.
Vishay SIR800 picture that I can find on internet. It has smaller dot printed.
And the Vishay SIRA60 I have bought has smaller dot too.
Here from an old mod:
And from a Manker U21 mod:
These were from ~2 years ago. I was buying the SIR800DP's from MtnE and maybe Mouser or Arrow at the time.
More:
The better 404:
Even better:
SIRA20DP spec sheet: https://www.vishay.com/docs/76212/sira20dp.pdf
SIRA60DP spec sheet: https://www.vishay.com/docs/66777/sira60dp.pdf
Maybe the A20 is slightly better, but some of the timing is a little slower.
Tom E, thanks for those pictures. There are a few differences compared to suspected fake SIR800.
1.The big dot on fake SIR800 is printed, I use a big magnifier and confirm that. While your pictures shows it should be engraved.
2.The big dot position on fake SIR800 is higher from the bottom edge.
In summary suspected fake SIR800 has cosmetic differences below:
The top picture is not showing up for me.
I happen to have some that I bought from MTN E a couple months ago. There is no printing on them, just laser etching.
