Judging from their past efforts (and VoB’s teardown) I think not at all. They look like they got some CAD whiz making cool looking shapes that many folks will oooh and aaah over. It’s laughable, because the active cooling for a 100W COB is about three times the size of what’s in the Imalent, only the Imalent has a crappier fan. They could have just made the finned heatsink and head one solid casting, then extended all the fins out to the exterior. It still wouldn’t be enough, but it would be a lot better than what they have now.
I hope Imalent listen and design a better active cooling.
And let user charge the battery easily without taking the light apart.
You don’t need hundreds of CFM because the body has surface area too. Manufacturers could easily make an extrusion with internal fins, exponentially increasing surface area. They could also add through holes to allow heat pipes from the head. There’s no rules stating that one must hold a flashlight from its body; a separate, ergonomic handle would be great - you can make it adjustable, and you can hook the handle onto your belt or backpack strap. And with the ginormous head this thing has, an external handle could have a more forward design, which would make the light balance better on the hand, instead of being head-heavy. You can have the handle mount to a t-slot in the extrusion, which would make it adjustable, and able to mount the light to whatever you want. And thus, you don’t have to think of the body as having to be round.
I mean, if they really wanted to sustain very high lumen levels in such a large head, rather than making a big heatsink with a lot of thermal mass, they should make a CPU type heatsink with tons of fins.
CPU heatsink you say?
I built a spotlight not long ago using a Fresnel lens, and an Osram White Flat 2mm^2 LED, mounted to a 90mm dia. x 50mm thick aluminum heatsink, actively cooled with a 12V fan pulling fresh air through the fins, and exhausting out the back. I’ve pumped a max 34W into that LED and you can feel the warm air coming through the exhaust end, even in the cold winter here. I can’t imagine a smaller heatsink and fan dissipating 20-30 times that power - just to squeeze out another 5 seconds of turbo time?
I’ll stick with the GT4 over the Imalent R90ts. With 18 LEDs I don’t see how those tiny reflectors will be deep enough to throw 2000 meters. And with the qc issues Imalent has had, not to mention the grossly exaggerated output numbers, I just don’t feel like I would get what I’m paying for. I don’t care if it’s a million lumens. Doesn’t matter if it doesn’t work.
I
The problem is that R&D takes time. A lot of it. Which is why it’s expensive, and why BLF lights take such a long time to make.
Did I mention 10% of my company sale went for new machinery and RandD? I could of just pocketed that and let the company rot away. Maybe even a few bank con jobs along the way.
As an engineer, I paid nothing for the actual engineering, but prototypes, trips to see machinery capabilities, making/modifying machinery, sending samples to customers, material testing……it’s expensive and chances are, the market won’t buy it.
It’s not surprising that most of the products out there are copies, or copies with a bit of a change. The vast majority are styling exercises. True usability/efficiency breakthroughs are not as common as they appear considering the size of the market.
Then there are the copy cats, mostly foreign and out ovf the reach of lawyers, that will suck away all the innovators hard work. And the retailers who don’t give a damn if some cut rate foreign company copied your product, as long as it was cheaper to them and more profitable.
Yeah, I have a chip on my shoulder about this…anywho, back to 1 million lumen flashlights.
Do you know that CPUs are in the 150 watt range? Some way higher. Yet they can run continuously with their fans on.
CPU fins and fans are available in surplus stores.
Any discussion on output sustainability and very high power lights has to start with fins and fans.
Ummm….you need the cfm to push the air through the fins. Passive or low air volume is not enough in close spaced fins. That is why CPUs have fans. Noisy fans.
But otherwise, keep going……you’re heading in the right direction. Forget the body, work the head. Lol
i was actually wondering: how mature will these lights be?
I know Acebeam takes many months before a light gets into production, but Imalent
seems to add them almost by the week....
That worries me a bit.
Im more curious all the legal stuff, can they get away with this, imean just looking the numbers if we asume its real, is there no limit for lights and how much lumens they are allowed to have? I also think on highest whatever the lumens it will pull u will probably get blinded on the ground just pointing the light , saw the same thing with acbeams x70 so much light goes into the ground and bounces back into your own eyes…. cant see how the max output will be high just a very brief moment :…
weird it has less intake holes then ms12 if that design will be final, looks weird that head is supposed to handle 1300w of power…
I’m more curious all the legal stuff, can they get away with this, I mean just looking the numbers if we asume its real, is there no limit for lights and how much lumens they are allowed to have?
No limit at all, why would there be? Maybe the Swedish government is a bit too “hands on”?
no i mean shipping them worldwide, really no regulations shipping furnace lights at all with serious flaws ?
Well, the batteries are fully contained in a metal housing. I think that’s the big thing with shipping batteries out of China. Some stores in China, BG, GB, AE, seem to be able to ship batteries in plastic cases. I’m not sure on the legality of that.
As far as flashlights, Customs doesn’t know if a certain brand flashlight is reliable or not. I’ve heard of zero cases of batteries combusting in Imalent lights.
The 2000 lumen GT uses 8 cells, the 100,000 lumen MS18 uses 8 cells. No big difference to Customs, really.
all that hatred and bashing does make some people here look like trolls...
please stay fair and constructive!
help us paint the picture about problems in the past from your own experience.
if 10 people say "I know their leds burnt in the DX80" and those 10 speak about the one guy who posted his personal experience we tend to think it's 11 dead lights ;)
I am sure if I took a Koenigsegg for the daily duties I ask from my Fiat Tipo it would break sooner than it should. (NO - I have no Koenigsegg ;) )
but for driving sportive if there is a hour available and sometimes on the track the koenigseck will definitely be the much more pleasant choice!
also I love to hear from people who had problems with their R90C, R70c, RT35 and RT70 - imho Imalent tries hard to improve.
or is there another reason why crowds with pitchforks and torches ( :D ) are rolling thru the forums every time when a few brands are on topic?
I have the Imalent DX80 for about a year. The second version. I bought from the EU warehouse for $ 216. For now it works perfectly. Just like HR20, DN70 and DM21T.
No complaints about the MS12 battery pack, from what i can tell its genuine Sanyo 20700, admittedly I am only going off the wrap colour lol.
first video
seems the cooling has improved
It looks like they’re using a single 30mm to 40mm radial fan. They also made it easily accessible by 2 external screws. This should make it easier to clean dust as well as to replace a fan that gets damaged or stops working.
Notice that Imalent is using non-anodized shoulder strap attachment points on the body and tail. Most manufacturers don’t so you scratch up the body; I’m glad someone is finally doing it right.
