For 9 emitters to produce 20,000 lumen each one has to put out 2,222 lumen (OTF). The best XHP35-HI with plenty of power behind it can only do maybe 2,000 lumen (OTF) and Imalent is not using the best leds (highest bins) and they have to share power from 4 x 20700 cells. When Vestureofblood recently measured the lumens on his R90C he got about 16,000 and wondered if something was wrong. I think that’s about right, 1,800 lumen each is a more realistic number. That’s about what the BLF GT puts out at 2.5A.
So I don’t think it’s hitting it’s claimed lumen rating. On the other hand, it seems to be exceeding it’s throw rating.
I really don’t know much about the MS12’s output. I guess not many people that have one have a decently accurate way to measure it’s output.
The MS18 and Imalent are getting trolled I agree. Is it out of line though?
The thread is dedicated to their two new lights. There’ll be some discussion on how they work, how their new cooling system works which there is. The majority of the discussion however will be peoples opnions and potential buyers voicing either their concern or their support.
I swore to myself that once somebody came out with a flashlight that broke the 100k lumen barrier I would buy one. I hoped that 2019 would be the year and based on previous drops X70 & MS12 I expected around Nov 2019 we would get the next versions which may or may not reach 100k lumens. Two months into 2019 its announced that Imalent has done it.
The skepticism is well founded and aside from the straight up bashing that can happen it’s very relevant when I’m considering a small used boat motor or a flashlight because the price in CAD will be well over $700.
I dug up the actual figures on lumens as they’re very relevant:
DX80 stated 32,000 tested 25,401 difference 6,599 overstated by 26%
R90C stated 20,000 tested 15,207 difference 4,793 overstated by 32%
MS12 stated 53,000 tested 38,952 difference 14,048 overstated by 36%
everybody overstates but by comparison Acebeam is much closer:
X70 stated 60,000 tested 49,691 difference 10,309 overstated by 21%
If we look at the way Imalent is gradually increasing the percentage they’re overstating their lights it suggests that the MS18 will very likely be overstated by 40%
with 40% predicted overstatement this light would produce 71,400 lumens at turn on
Incase anyone doesn’t understand my math: 38952 is the MS12 output so the difference of 14048 that is added by imalent represents a 36% increase of the actual output 38952
Probably talking about me! That is ok,I speak the truth backed up by others and my experience.So it is EASY to use V54 as an example,and I do!
,Because his lights have MORE output than these manufacturers do, as they should.I simply pointed out that he crossed[legitimately] the 100K lumen mark before the aforementioned manufacturers.
You obviously are not fond of him[expressed above], so it is no surprise that if someone else is, it seems to bother you.
Even if Imalent overstates their lumens by 30% and the MS18 peaks at just 70,000 lumens it would still hold the record for output in a production light. That’s still something to be proud of. Imalent has produced some flawed products in the past. However, kudos should be given to them for:
Being extremely creative and innovative. For example: no other manufacturer ever came out with a variable tint light controlled via a slider on a touchscreen display like Imalent did several years ago.
Pushing the envelope. They are one of the few manufacturers showing us just what is possible in terms of output with LEDs these days.
Coming out with new models rapidly. It’s nice to see rapid releases and improvement. No waiting years for a new model from this manufacturer.
Addressing issues when they are found. From reading this thread it looks like when issues were found with the MS12, they did a recall and incurred massive expense in redesigning the head to fix the problems. The resulting new light is impressive. Not every manufacturer would do that. They aren’t perfect, but their heart appears to be in the right place.
They appear to be learning from their mistakes and some of their products are excellent.
Looking at the Imalent failure poll, I will never own one. 700.00 for a bulky, heavy light that probably is over rating it’s lumens, and is most likely not reliable is a non starter for me. I also don’t like lights that need a fan. Everyone thankfully can buy what they want, and for those who like this light, go buy several.
I also have no need for a gigantic light. My needs are more about what I can fit in my pocket.
But just because I’m not going to purchase a gigantic light doesn’t mean I’m not interested in seeing what’s happening at the cutting edge. It’s quite interesting watching manufacturers fight to produce the most lumens.
If my opinion was perceived as bashing that was not my intent. I don’t recall telling anybody not to buy one. But I stand by what I say and what I said is relevant. These things aren’t cheap. People need to be informed of possible issues before they go and spend $800+
That being said… Even if the MS18 only does 71000 lumens, that’s still incredible! I hope it hits 100k lumens and I’ll be the first to say that if it does, I’ll be in line to buy one myself.
Imalent seems like they’ve designed a head profile they like and are going to stick with it for many models. As someone else mentioned, a 12 cell set-up would be much better for a 100 000 lumen light.
how much would that thing weigh though? assuming they’d use the same head.
Would it also basically be as long as the infamous 6D maglight?
It’s pure business decision… They’ll “destroy” their reputation to a few hardcore enthusiasts and lose them, but gain a few sales from the uninitiated. Every business does a cost-benefit analysis, and unfortunately many bean-counters are not customer-relations experts. Or engineers.
I think the lights Imalent make are fine, even good, and they have enough WOW factor in them that there’s really no need for blatant false advertising. It’s like playing poker with two crooks - “You got 5 queens? I beat you with 7 jacks!” It’s almost like the manufacturers peruse these forums, get Texas Ace’s or koef3’s or maukka’s or whomever’s test results (that are done on a huge actively cooled heatsink) and multiply it by the number of emitters to come up with their numbers.
Take the DX80 for example. Yes there was a recall, but they got to have known they were shipping a defective product. It’s almost like taking a defective product, selling them as a way to raise money, then ship replacement parts afterwards. Not saying this was the case with the DX80, because things happen, but it makes you wonder if with more extensive testing, there would have not been as much a recall as there was.
Seriously agree that there’s no need for the overstatement. This light might very well produce 70 000 lumens. Why not call it a 75 000 lumen light. LOL either way it’s still the KING
Kinda like: so I’ve built an oldschool muscle car dragster that has 1700 HP which is astonishing yet I decide to tell everyone it makes 2050 because I think it sounds better.
The difference is, the BLF light will come close to, or slightly exceed, its output and throw specs. The GT4 is not intended to be the swath of light this is. It’s intended for large down-the-range lighting.
That said, I think a higher powered version of VoB’s GT COB conversion would probably be a more useful and practical light than these mega multi-emitter lights.
I have not experienced any problems with my Imalent lights yet.
I tested two R90C in my TA lumen tube and they measure about 14k lumens at turn on with some light leakage because of the large head size so I estimate about 15k lumens. Light is still very impressive though but a bit disappointed that I bought it so soon since R90TS will likely be 30k lumens
I don’t have a problem with the flashlight itself nor concerned about it’s quality….because i will never buy one.
In an open forum, conversation will deviate and the OP should expect that. Also should expect the criticism of the product. Particularly if the claims are not backed by actual testing and proof.
I think there would be a different conversation in here if there was proof of 100,000 lumen running, even for a minute or so. Without proof, it’s legitime conversation to question the claims.
I don’t know what you are reffering too, but if there is one wow light that i will force open my wallet, it would be for that light on youtube with the 38mm LED.
Here’s the deal: They could have used 24 XHP 70.2s, ran them at a more reasonable 12V and 2.4A, and produced 100k lumens rather “easily,” while using about 30-40% less power (less heat); AND have enough overhead for turbo.
