same settings
MS18 (97700+ Lumen)
R90TS (30800+ lumen )
same settings
MS18 (97700+ Lumen)
Got to give credit where due. That is seriously impressive.
I really don’t know yet if the throw distance on the R90TS is any better than my R90C, though lumens are definitely “doubled” based on realistic figures, so that’s good, but at the same time the R90C has close spill. I really like it because I can see my entire yard and the ridge behind me, but some may not like all that spill. It will be interesting to hear some opinions on the the throw, the spill, and the efficacy of the objects at distance, and photo comparison to an R90C. I know Martin has both
Like I said a month ago about these high power lights, they don’t have CPU style cooling to keep temps down, sustained output will be rubbish. In other words these lights will just be toys.
Two on my wish list.
And thanks a lot for the info Martin!
Relax “nokoff” its not that serious its just a toy, like a video game for kids.
Huh? Two different lights. Very different designs and price ranges.
This is ceiling bounce comparisons or what exactly?
Curious what lumens he assumed the MT09R to be. Hakelite over spec the lumens on the MT09R. If this even makes 80k lumens, it would be really amazing since all flashlight manufacturers seem to use a reference that is 20% higher than the Maukka/ANSI standard.
Is Imalent planning to release a NW version.
Yeah right.
MS18 : 98k lumens 350kcd
R90TS: 30k lumens 800kcd
Which one should I get?
My two combined MT03 has over 32k lumens but they can only do about 75kcd. MS18 350kcd is very impressive too.
But I think R90TS will be more sustainable in terms of heat and power consumption.
Is it fan cooled?
Wait for the GT4 to come out for a final decision between it and the R90TS.
Have to ask Martin or ZozzV6 whether R90TS has fan cool. I would say it should since externally they looks 100% identical. Imalent will save cost if having similar parts for these two lights.
100% an argumentative troll and shill, BLF was a better place before he unfortunately joined us
I don’t understand how he is a troll. Some people are passionately loyal to a brand and that is not uncommon. Not sure why that is a problem. Skylumen does make good lights as I own a bunch of them.
He never posts (gloats) without comparing stock lights to his overpriced V54 modded lights. He is a shill and a nuisance
It’s better to just ignore his posts than to bring attention to them.
You are basically “feeding the troll” which is never a good idea.
If one of those VN lights could run longer than stock on highest output without shutting down or burning my hand I would drop some serious money on them.
subscribe to my channel and activate the notification
I’m just now watching Martin’s video that went live recently.
It seems the MS18 and R90TS have 2 fans (30mm I believe) in a push/pull configuration. They are using heat pipes as well. It seems odd, but I guess the pipes makes an improvement over not using them.
It’s a bit strange that the R90TS has smaller diameter reflector cups for the 6 xhp35-HI in the middle compared to the bigger cups on the 12 emmiters around the perimeter. I guess they ran out of room. Would having them all the same diameter be better? IDK. It means 12 emitters have a tighter hotspot than the other 6.
