Imalent MS18 with 100,000Lumen and R90TS with 36,000Lumen
Do a quick search on his posts, you’ll find an incredible % of them mention / gloat about his V54 lights, I’m not kidding.
I own half a dozen of his lights too, but I don’t use every second post as a way to promote them or Vinh
ZozzV6, is R90TS using XHP35 or XHP35 HI?
YouTube
XHP35 HI
2.3A per led.
Thanks for making the video in the wind guys!
The R90TS vs R90C is right at the 10:00, easy to find again lol.
Throw-wise I can see a bit better reach on the TS, and definitely more spill immediately in front of you. This is not a pencil beam thrower (I own a few) and I actually like that spill on my R90C. Looking forward to more of your thoughts on the TS!
We told Imalent to lower the current to 2A per led on the TS bevsuse over that not much lumen gains but more heat. And maybe it will be only 28000 lumens but more sustainable runtime in turbo.
Outside in 10°C and heavy wind they keep up very well but inside in the room they get hot within a minute. And when powered off still warm after 10 minutes. We did not measured stepdown times and what is the sustainable output for long time because we did not have that much tim to charge them multiple times for those measurements.
Thanks Martin and ZozzV6 for the efforts. Imalent really listens and improve their giant lights.
Looks like hardware performance wise they are excellent, hope they get the firmware and user interface right for final product.
I wonder do they plan to have momentary mode. It will be really fun to switch on and off them quickly, like man made lightning.
OK,so it is all right for you WITH NO REASON to insult me and then when I comment back to you I am getting the last word! lol!
Look who told Blinkinglights to F himself when he did nothing wrong!
The problem with a lot of you guys is you have Double standards! :wink:
Thanks for the video guys! Man you look TIRED! Clearly shows how excited you were to power through without sleep!
lol it definitely seems like the cooling situation was vastly improved because that thing sounds like a hair dryer when the fans are on! In fact that cooling system appears to blow away anything Acebeam has shown so far! (X70 production or pre-production prototypes)
:person_facepalming:
I hope some comments above can be edited in case they contain rude words against Imalent based in fictious numbers and assumptions ;)
new, uneducated members and guests could get a wrong picture...
After watching the video I’m definitely more excited! Still a little wary but from what he showed so far it really looks like Imalent is trying HARD to listen to the community feedback and make significant changes in the directions we’re asking for.
Given that the MS12 production version had barely any QC issues especially when compared to the DX80 it seems like they’ve really taken their past mistakes seriously.
If lumen measurements keep coming back with less than a 5% difference between stated and claimed….
I won’t be able to NOT BUY ONE :person_facepalming: Lol
People ask me why I need a 32 000 lumen DX80… lol now to try and explain why my 32 000 lumen DX80 isn’t enough… ha ha ohhh man
Martin! thank you for your very hard work!
I wanted to ask you about your other comment that really confused me?
I saw it was clarified as the MT03 TA not the MT09R but was the number a typo? did you mean it had 11200 lumens not 112 000 right? Or am I missing something? Also even more confused because the MT03 should be a lot higher than 11 200 and the MT09R sounds about right at 11 200… lol like I said, I’m confused
He meant the MS18 measured 97,700 lumen and 112,000 lumen using those other flashlights as a comparison.
MT09R was a typo. 112000 was MS18 with the higher multiplier we first got based on a weaker flashlight (Convoy L2). So 97966 is our weakest guesstimate for the MS18 based on MT03 xalculated multiplier because it has more close beam pattern to MS18.
correct
ZozzV6 has a calibrated tube
we measured the flashlights in the tube and the integrating bathroom. comparing those tube lumens to the bathroom number gives a correction factor. multiply this factor by the MS18 bathroom number gives MS18 Lumen
2 Convoy L2 (xhp50.2 and luxeon) and a DS20 gave a factor of 15.6
ZozzV6 Haikelite resulted in a 13.55 factor
we took this because it gave the lower!! result
that way the MS18 was tested with 97966 lumen compared to the haikelite
(and 112788 lumen against the 3 other lights)
hope you can understand?
Any idea what 21700 cells they will be using?
Battery life running at 100k lumens will be shocking, but never the less, i still want it :smiley:
Probably the R90 is the one to buy.
Samsung 30T obviously.
We didn’t asked. And battery pack is closed by factory in the tube. So users can’t open and replace cells just complete pack.
