[quote back from Arrow]
(https://i.imgur.com/4WSBkgS.jpg) a few minutes ago. The caveat is “pricing and lead times are subject to change based on the factory/supplier conditions” . In other words, no firm time frame. Couple that with Zebralight’s message.
But I agree, if he could get them, spreading them across the other models would be great.
My experience with the XP-L HI wasn’t that great. It showed significantly more abrupt CCT shift in the beam then either my 219C or SST-20. The color temperature was also about out of spec. to. I had a 2700K model, and it’s actual CCT was over 3000K. The yellowish rings in the beam were in the upper 2900K range.
The SST-20 delivers its promised CCT better then the XP-L, and it has far less chroma shift about beam to.
The 18350 proportions look off to me. Functionality wise, if you are carrying such a big light, may as well use 18650’s and have a good grip on the light.
On the other hand, I suspect alot of people would want to buy the shorter tube for a few dollars extra as a secondary option. I would be curious even for myself! Could make a cool table top lantern. That would actually be a good accessory for it, a lantern diffuser made to fit.
3 x 21700 are about the same diameter as 4 x 18650 and only have a tiny advantage over 4 x 18650. Hank wanted to keep the light small.
It does require at least raised flat tops. It should have a ring on the driver like the Meteor and Q8 (based on the battery tube spring board). There are a few raised flat top 21700 on the market, but not too many. There’s even less button top 21700 currently on the market so 18650 does make the most sense.
