I hope you never accidentally put a battery in backwards. I did that one time and it was a huge mistake it destroyed my entire charger. I then redid it on video and sure enough there’s no reverse polarity protection and it fried.
If I remember correctly on power up the fan self-test maybe twice and then goes off it will only kick back on if charger is warm enough inside
PERFECT user name for your fan,A FLUKE!!! LOL! And I am not talking about the DMM By Fluke!
Quieter.Yes. More powerful? Not a chance! The reason it is quieter is because of its inability to MOVE air as well[CFM]. The specs and difference in performance have proved it.
The reason mine is a little louder is because it has a much, much better ability to MOVE air[CFM] which keeps the charger cooler and operating better.
There is NO comparison b/w the fan you listed which is similar to the STOCK fan and my TOP TIER DELTA fan that I have been using for almost 2 years.
No more stoppages during discharge tests which gave inaccurate capacity readings and no more RESETS at the transition from discharge to charge. Believe me, read my thread, I did extensive testing to come to these conclusions!
Specs. for fans: DELTA: 25mm X 25mm X 10mm——————-ADDA:25mm X 25mm X 09mm. The only difference is 1mm in depth.
Stock[ADDA] fan- 5v/0.13a/0.65W,In terms of specs, basically the same fan as you posted.
Delta fan- 12V/0.12A/1.44W,MORE than Double the Watts to power the fan!
SPECS for delta fan. CFM [Air Volume] is the key,IT is superior to the stock fan and the replacement fan you posted. iirc their CFM is about half!
There are several factors. My DELTA FANS HAVE 5 blades,the stock fan and yours have 7 or 8 blades,quieter,and again,does not move air as well.
My fans,more expensive but well worth it. I got mine for FREE[2] from a dealer in California who was following my thread and wanted me to test his.This is another source.
I did not know any of this until my Opus gave me problems 2 years. Dr. Gauss and others helped me understand it and suggested the DELTA replacement fan and the LITE-ON Power supply. Between the Two it is like a brand new charger.
I’ve got a BT3400 v. 2.2 and its OEM fan has been quiet, but I bought two of the Delta fans off of Ebay just to have as spares, as Wolf has suggested.
I also bought the LiteOn 5.5A 12v power brick and while I don’t use it regularly, it was fairly cheap to get ($12 shipped?) My inner hole on the barrel connector is slightly over sized, so if I jiggle it when the charger is running, it’ll disconnect, but I just don’t move the charger once things are charging.
Thanks Wolf. I’ll take a look, but it’s more of a minor nit. My 2A wall wart works fine, although my first one from Rdana crapped out on me @ 4x1000mA. charging.
I’m still using my original fan ,it got noisy once and I just gave the housing next to the fan a few flicks & it’s never done it again.
I have opened my opus a couple of times & while it was open I took the fan out & took all stickers off it & sprayed it including the windings with spray on 3 in 1 oil.
Hey wolfdog you sent me link in the other thread for the adaptors from alixpress, they fit good & are right angle.
