I do have the old style RRT01 on the way, jon_slider liked his so much I had to try the old style too and I’m pretty fond of the new style. If anyone needs a measurement or something feel free too ask and I’ll check when it gets here. I’ll probably mod it shortly after I get it.
[/quote]
might I ask how it is that you have one of the old style on the way? Few and far between I think?
From the link in this thread, post #214. WTB: Jetbeam RRT01 – Any place to buy it?! + [RRT01 2019 discussion] - #213 by wynand
I emailed them and ask if they would ship to the USA. Tom said they do it all the time and that would be no problem. I couldn’t order from the site because my country didn’t have a shipping option, so I created a account and emailed them.
Tracking say’s it’s all ready landed in New York, 3 days from when I ordered. From the emails we had, seemed like a pretty good bloke.
I noticed this too. The centering has a square cutout on the bottom, the same size as the ledhole but not all the way thru and 45 degrees rotated. The led sits in this pocket now.
I use thick yetzl silicone grease from fasttech. It’s too thick for normal thread lubricating, but perfect for this. I have it in my V11R also and it holds up very well.
I agree it’s very quick if they removed the detents because of our comments here, maybe they had the same conclusion after producing the first batch.
Ahah, thanks As I started the thread long ago with WTS part, I thought it ma be confusing (even after I added the “discussion about the 2019 model”)!
Thanks for clarifying :+1:
I was looking for a good led for my RRT-01, it has to have good output but also a good tint 4000Knor less and great CRI, and the die size is not important. The output requirement limited me to LH351D and XP-L Hi but of both I have never seen the combination of good tint&CRI. Then I thought about the 4000K 90CRI XP-L2’s that I still have a bunch of, they have ugly green tint and the rainbow beam but perhaps slicing/dicing one would help. So I did:
It did not work out perfectly, the tint of the hotspot was 3600K, and just 89CRI, with R9 only just under 50. The green was gone and now only slightly above the BBL but it was still not great. Furthermore the rainbow was better but not completely gone, and there were a few more beam artifacts. The output was very good however, the same as the cool white XP-L Hi: just under 700 lumen.
So now I swapped in a SST-20 3000K, and am still not happy. The Jetbeam reflector is pretty unforgiving and still shows artifacts in the beam, faint rings where I do not want them.
Next try is a sliced LH351D.
Btw, you can get to the led in a conventional way, just screw off the bezel and remove lens, o-ring, reflector and centerpiece. Only con is (un)soldering the led wires inside a deep hole.
I agree that the sst-20 is a bit ringy. If I remember correctly it was a bit better with the 45 degree rotated centering ring I had, but not sure. Maybe I’ll check it if I have it open again.
Where the rings also there with the original xpl-hi? I never really tried it.
