XM-L T5
56 posts / 0 new
old4570
Last seen: 3 weeks 13 hours ago
XM-L T5
I got me a XM-L T5 from cutter , and since it was a T5 I put it into my Ultrafire A20 ...
Well , all I have to say is holly cow !!!!!
Its gone from 250L to over 600L ,  The beam shape / composition is almost exactly the same as the SSC P7 , so dont expect a spectacular thrower ...
My HS802 has a MC-E in it right now , when I get some T6's , I will do a transplant , [ HS-802 is a tight pencil thrower with XR-E emitters ]
BAck to the A20 , I left the original driver in place and just swapped in the emitter [ XML T5 ] , I havent measured current as yet , but I will do beamshots etc when it gets dark .
Here we go :
High / 1.77A / 620L
Med / .69 / 250L
Low / .25 / 100L
Beams after dark ....
Here you have a nice clean view of the XM-L T5 in the A20
And here is a picture of my A20 [ 1 x RCR123A ]
http://www.makeagif.com/91KWYL    Link to animated gif of beams ...   http://www.makeagif.com/xrvpJ2     Slower version !
http://www.yourfilelink.com/get.php?fid=595720    Full sized images to download if anyone wants them [ Win.RAR ]
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: old4570 on 12/20/2010 - 15:44
brted
brted's picture
Last seen: 4 days 22 hours ago
It's a lot of light! The group buy at CPF is finally gearing up and I'm wondering what I should ask for. Since I already have a drop-in, I'm thinking of just getting 1 T6 mounted to a 14mm board to build my own P60.
That's a huge jump in output. Maybe it is direct drive on High? Sounds like basically you've got a Quark MiNiX now.
old4570
Its a pocket rocket now , and gives my P60 [ 18650 ] SSC P7's a serious run for there money ....
T-6's have not arrived at Cutters as yet , they did have the T5 , so thats what I got ...
But looks like XM-L might be the go , though I dont know how well they will throw , yeah , those important beamshots ...  [ tonight ]
I will compare to my SSC P7's ...
cabfrank
and it sounds more and more like the xm-l's are going to make a lot of other emitters second class. thank you to all of you for sharing your preliminary results.
old4570
OK , all my SSC P7 [ single 18650 ] are around 500L
The little A20 on a RCR123A blows them all away ...
EVEN the SST-50 [ mine did 500 ]  is rubbish compared to the XML ........      Howzat !!!
I cant wait to get my hands on the T6 's and build some P60 drop ins [ RIP = SSc P7 / MC-E / SST-50 ]
cabfrank
though, for all out there that are far more expert than i am at this, will it be viable in a small, say 14500 or single 16340 host?
brted
brted's picture
Did you get a chance to measure a tailcap current yet?
old4570
Updating original post as I go ....
Yes , Im sure you can use the XM-L with a 14500 or 16340 light [ I did ] .
Just cherry pick the driver you want to use , since I dont care about shortening the life of a RCR123A [ I have plenty of them ] , and I also usually dont run high , except to show off , and as can be seen , on low , its 100L .  Damn , a 4 mode driver or ramping driver would be real nice [ for less than 100 Lumen output ]
Butt , 0.25A and 100L   = I used to think 0.25A was OK for low , not anymore .
fran82
Last seen: 12 months 2 days ago
@old4570
Is this possible?
High / 1.77A / 620L
Med / .69 / 250L
Low / .25 / 100L
620 lumens with only 1,7Amps?
250 lumens with only 0,69Amps
100 lumens with only 0,25Amps?
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Budgeteer
Budgeteer's picture
Last seen: 8 years 2 months ago
Seems a bit overrated since there were reports of 600-700 lumens at 2,7A
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
jekostas
Last seen: 10 years 1 week ago
fran82 wrote:
@old4570
Is this possible?
High / 1.77A / 620L
Med / .69 / 250L
Low / .25 / 100L
Cree's documentation on the XM-L is 260 lumens at .7 amps for the T5 bin.  658 min flux at 1.77A to the emitter by those numbers.
fran82
ummmmm If this is possible I will transplant many of my lights to xml
Budgeteer
Budgeteer's picture
If it does true 600LM at 1,8 its a real winner!
fran82
yep the forever substitute of the P7´s
Budgeteer
Budgeteer's picture
And with better tint!
old4570
The current measurement is as measured :  I cant measure current and light output at the same time [ Id need 3 hands ]
So it may not be entirely right , current may be slightly higher in use [ less MM ]
Unfortunately the A20 unscrews in the middle ...  This is only as a guide , sorry , I dont expect it to be 100%  , but just to give you an idea ...
Its getting dark now , Ive charged up some 18650's for my SSC P7's , so lets check out the beams ...
But yeah , a bad light for matching current to output , I should have some XM-L T6's in a day or two , so I will build some drop ins for my L2 Hosts
Then I can measure current and output at the same time ...
Beams shortly
rzezniq
Last seen: 9 years 1 month ago
620 LM form 1*16430 light.... The world just went bananas.....
Very nice mod!
old4570
Try this , beams as gif ....
Its cloudy , so way to much city lights [ reflected from clouds ] , so very bad conditions for beams , but hopefully you get an idea ...
brted
brted's picture
That's a neat way of doing beam shots, but can you slow down the frame rate a bit? I don't have quite enough time to look at the picture *and* read the caption. Maybe 2 seconds per frame?
fran82
can post them right here one by one?
xP.1337
is cutter selling them with 14mm boards yet? cant find their board size on their website
uncajesse
Last seen: 1 year 1 month ago
Nice GIF, I'm glad I got the larger reflector of the C8, even though several of those XM-L lights have literally the exact same beam shot images on KD. :/ The A20 is not quite big enough even for a flooder, but DANG can it flood. Big Smile Awesome.
old4570
Cutter has 14mm boards ...
Posted a link [ first post ] for full sized pictures if anyone wants them ...  Will try for a slower gif
old4570
Here it is slower
old4570
Actually the little light is so bright [ spill is brighter ] it makes it look like it has more flood .. [ I guess it has brighter flood ]
+ the flood is so bright , it makes the center look darker [ optical illusion ]  , I guess the camera cant see what the human eye can ...
Thats why I posted a link for the larger images if anyone wants them ..
Unfortunately I dont have a digital SLR with timed exposure , so the pictures do LIE a little ...
But the little XM-L T5 is hot stuff ..    Just cant wait for the T6's and hopefully drive them much harder ..
I might buy another T5 , the tint is just perfect for me [ and see how hard it can go in a P60 host ]
XML rules !
But just to say , to the naked eye , it was just awesome , so much light from a EDC , its a sight to behold ...
Kokopelli
Kokopelli's picture
Last seen: 2 years 7 months ago
I have a A20B on the mail. I were planning to use it as is but I can transplant its R2 to a thrower and an XM-L or XR-G into A20B. How does it mod? It requires 14mm emitters at most I belive, am I right?
I don't have a 14mm XM-L right now but a 12.8mm R5 is also on the mail. I wonder which one would be most efficient at something like 1.2A current to LED.
old4570
14mm would probably be the go ..
XM-L is the most efficient , then Xp-G ...
First thing to watch for = Is the emitter glued down ?  Might make it hard to remove without destroying it ...
Then you need to glue the XM-L in place [ thermal epoxy ]
Do you need a new driver ???   or do you wish to use the original ..
Soldering ?
Checking for shorts [ XP-G / XM-L design lends itself to shorting , especially with reflectors that press down ]
Moding is a learning experience , be prepared to break stuff ...
Kokopelli
Kokopelli's picture
I'll better reserve XP-G leds to 2xAA lights as boost should work better with a lower Vf. I guess any 18650 light can unleash the potential of an XM-L. I plan to start with something with more space, like an UltraFire C8 or a bigger TR-1200 body. Ordered my insulators, thermal epoxy, 2.8 linear and 3A buck drivers, empty P60 drop-ins, Dremel tools and so on... Smile
Don
Don's picture
I did see somewhere on CPF that an XP-G R5 was brighter than an (unstated bin, probably T5) XM-L until you went past 1500mA. But my memory may be at fault. The XM-L is more efficient at any given current, but not necessarily brighter. It is when the XM-L becomes much less efficient that it gets really bright. The same is true for most LEDs
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
brted
brted's picture
I don't think that's true about the output. Cree determines the bins at 350mA. So a higher bin will always be more efficient and put out more total lumens at pretty much any current than a lower bin. Now the brightness of the LED die itself (and therefore the throw) may not increase for the XM-L until you get past what the XP-G is rated for which is 1500mA. That's more of a lumens/mm2 thing though.
sixty545
Last seen: 1 month 1 week ago
That is not quite true. XM-L's are binned @ 700mA
