I got me a XM-L T5 from cutter , and since it was a T5 I put it into my Ultrafire A20 ...
Well , all I have to say is holly cow !!!!!
Its gone from 250L to over 600L , The beam shape / composition is almost exactly the same as the SSC P7 , so dont expect a spectacular thrower ...
My HS802 has a MC-E in it right now , when I get some T6's , I will do a transplant , [ HS-802 is a tight pencil thrower with XR-E emitters ]
BAck to the A20 , I left the original driver in place and just swapped in the emitter [ XML T5 ] , I havent measured current as yet , but I will do beamshots etc when it gets dark .
Here we go :
High / 1.77A / 620L
Med / .69 / 250L
Low / .25 / 100L
Beams after dark ....
Here you have a nice clean view of the XM-L T5 in the A20
It's a lot of light! The group buy at CPF is finally gearing up and I'm wondering what I should ask for. Since I already have a drop-in, I'm thinking of just getting 1 T6 mounted to a 14mm board to build my own P60.
That's a huge jump in output. Maybe it is direct drive on High? Sounds like basically you've got a Quark MiNiX now.
and it sounds more and more like the xm-l's are going to make a lot of other emitters second class. thank you to all of you for sharing your preliminary results.
Yes , Im sure you can use the XM-L with a 14500 or 16340 light [ I did ] .
Just cherry pick the driver you want to use , since I dont care about shortening the life of a RCR123A [ I have plenty of them ] , and I also usually dont run high , except to show off , and as can be seen , on low , its 100L . Damn , a 4 mode driver or ramping driver would be real nice [ for less than 100 Lumen output ]
Butt , 0.25A and 100L = I used to think 0.25A was OK for low , not anymore .
That's a neat way of doing beam shots, but can you slow down the frame rate a bit? I don't have quite enough time to look at the picture *and* read the caption. Maybe 2 seconds per frame?
