Just tried to resister mod the h2-c driver from KD. It’s is now garbage, stuck on low power blinky mode. The driver also uses an different layout (compared to the pictures in the convoy L2/l6 mod thread ). The sense resistor on my version also had an r50 instead of the r100.
The sense resistor was never an R100 in the H2-C Hellie112. Jensen567's early unit had two R100 resistors stacked, that equals 50mΩ (=R050).
Carefully check what you did to the sense resistor or other parts of the layout. “Low power blinky mode” looks to be low battery warning. If you have increased the power output and are using just 1 cell as input bear in mind other parts in the circuit causing voltage drops need to be optimized, this means good switch and well done spring bypasses or high current springs (you should optimize the current path anyway). Maybe you went overboard reducing the sense resistor.
I didn’t had much time this afternoon. Guess never mod when you are in a hurry But a trace on the backside (close to the spring) was completely burned. Did a bypass but now the driver pulls 10 amps (at the battery)… no change in output when changing modes. But I still got the flashing mode…
I have a KX70 driver that has been modified exactly as Jensen567 had detailed, putting on a 2.8V LDO, moving the cap, with .01875 sense resistor. Everything seems to be working, except for one thing. The driver doesn’t fully turn off. The momentary goes through the modes using 1 press per switch, and it doesn’t seem to cycle off, so I hold to momentary down, and it seems to turn off, except the led (XHP70.2) is slightly lit, almost like a moonlight mode. Is there anything I’m missing?
Looks like an H1-A with downgraded inductor (?). I wonder how much of an actual impact that has when increasing the current/power output near the TPS61088's integrated switch current limit (10A). Thumbs down of course.
We are still a ways off from having universal boost drivers that can run NarsilM or Anduril or just an E-switch in general. You will also loose the charging.
The few universal boost drivers out there are limited to whatever brightness levels and UI it comes with. I am still waiting for better drivers.
Universal? What do you mean by universal? For universal things to exist as a rule most people would need to develop its consciousness and themselves a good deal more.
NarsilM? Anduril? What gives? I Hi-Lo-Strobe :-D LoL.
In all honesty, using fantasy names for microcontroller software may sound compelling for the freaks. For people outside of these circles, definitively not. I've been around here for some time already and I've never used a torch with software of that class, for example.
I would choose a descriptive term. For example, Advanced Multifunction Flashlight Firmware vX.Y.
Of course I have to admit NarsilM or Anduril are terms which completely fail to inspire me. I prefer DynamiteBundle or BonnyC4Piece instead.
I mean like the same driver design available in a variety of sizes like 17mm, 19mm, 20mm, 22mm, 26mm, 30mm, 46mm. Maybe the bigger drivers have more power, but the basically the same design.
This is what MTN E and Lexel are working on. A good boost driver design that can be made in multiple sizes using an e-switch and some nice ramping firmware. Lexel is working on Anduril and NarsilM while MTN E uses RampingIOS.
MTN E has released a few sizes of his boost driver, 17mm, 20mm and 22mm, but they are not ready for e-switch, yet. Lexel has not released any of his yet.
I am not interested in tail clicky, Hi, Med, Low designs.
A potentiometer is like a variable resistor. The firmware in that driver looks for a brief loss of power (it uses a capacitor to keep it’s MCU “clock” running for a few seconds) to recognize when to change brightness levels. So it is two completely different things.
I can’t say for sure as I haven’t tried it but adding a pot would probably have to be done using a PWM circuit controlled by a pot.
I have used this simple 555 timer circuit a few times to add pot controlled PWM to circuits that accept pwm input.
On the H1-A, cutting the trace from the PWM output at pin 5 on the MCU and adding the circuit above with the pot controlled pwm output tied to the the cut trace might work. At least that’s how I would try to make it work.
So could the 555 timer circuit be added to a cut pin 5 trace for variable brightness or does it not apply to this circuit.
I think you have a little more electronics back ground than me, that’s the reason for asking.
Thanks. Don’t mind loosing charging but the UI is a pass for me too. What’s the sticking point for those working on making them? To a complete layman? Keeping the voltage boosted while all the possible clicks/outcomes?
I really don’t have much of an electronics background. I know a little about FET drivers, but just the basics of Boost and Buck
I know some boost drivers are designed to accept pots to control them (like this one), but the HA1 is not one of those. I believe your talking about cutting the PWM output trace to the OPA333 and adding a new opamp that can be controlled by a potentiometer. Maybe it can work? It is beyond my knowledge.
