The cost would be:
Oof
But, it would be a nice idea for a much more expensive spring.
Nickel-copper(50um)-Gold plating for the best setup possible.
The cost would be:
Oof
According to Engineering Toolbox, both Copper and Silver have better conductivity than Gold. The only advantage Gold has is that it doesn’t tarnish or corrode.
Also, when not tarnished/corroded, a silver plating is actually better in terms of contact resistance and conductivity.
Gold would be the best option for no oxidization or resistance to sulfur degradation(tarnish), but would be prohibitively expensive for “small batches”, since there is a MOQ for gold salts used in electroplating.
Something like this would be dope though, although I would not like to see the cost per spring at that point:
Flash nickel-Silver(50um)-Gold(10um)
Hopefully mine will show up this week. Already have a project awaiting them. I’m excited. Ever priced a braided wire spring? Bet those would be high. Would look awesome in a custom light though.
Actually, no, but the work involved probably makes the cost prohibitive, especially in developed countries.
On that point though, the best we can get in terms of springs contacts, for now, are dual BeCu multi-layer plated springs, meaning we are limited to 20-23A of current.
I’ve been looking into other solutions that can handle even higher currents, but designing one that can fit a standard flashlight and multiple cell sizes will be very challenging, and I’m venturing into completely new territory.
Even then, just asking if multi-layer differential metal plating was available for electroplating to the spring company made them surprised, and they had to go and ask the electroplating company directly.
The response itself was even more surprising since they said very few companies, let alone individuals, do different metal multi-layer electroplating, since it’s mostly reserved for very high performance stuff, and most companies prefer using the standard nickel/silver/gold plating.
Back on track, just designing the current springs took a lot of time, math, research and effort, so this next one would be the real challenge.
If I could manage to do something like this myself, then it would make bypasses a thing of the past.
What do you mean by this?
A design that can equal spring bypasses even in the most extreme of cases, that can fit standard flashlight tailcaps, driver side tailcaps, etc.
Even dual BeCu springs hit their limit at extreme currents(23A+), and spring bypasses become worth it if you have the battery and light setup to push past that.
Meaning with a 20700/21700, it becomes viable again to use spring bypasses,
I want to equal spring bypasses in every way possible. That is my goal!
This isn’t my final goal though. I didn’t exactly tell people here that I’m not only looking to make springs for flashlights, and
I’m designing something else too which does use springs, but something that ends up being more… impressive.
Received mine, thanks Blue!
Will be in for some gen 3 when available, look forward to following your exploits in getting to that stage.
I think that’s a fair description of the lights you’re designing these springs for
Yes, but they were surprised I was doing it for flashlight springs.
What most companies do is just straight up doing multiple baths.
It does end up in thicker platings, but can get extremely expensive, and plating time becomes slower as the layer becomes thicker.
Doing multi-layer differential plating is something that can be used to bypass that, but being more complex and requiring more calculations, apparently, most companies don’t bother doing this, except for very high performance stuff as mentioned before.
Seems like flashlights spring are going on the bleeding edge
Mine arrived! My wife was standing there and tried to confiscate some of them because they are so pretty, saying she could make something out of those. I bought her off with the promise of a new flashlight. (She didn’t know that one of the FW3A’s on my list is for her anyway)
My wife and daughter both agreed they’re very pretty… almost jewelry. But, when I asked my wife if she wanted a couple of them to wear as earrings, she didn’t hesitate to turn down the offer. She’s not really into “unusual” or “interesting” jewelry. Oh well. :laughing:
Maybe I should stay with a silver plating then.
That would make the multi-layer plating more expensive though, but the added beauty and lower contact resistance would be a nice boon.
Received my order BlueSwordM! Excellent stuff! Thanks!
Package received, thanks. Shipping is extremely fast 27.03(on letter) –6.04
My springs and SST-20’s came in today. Thanks BlueSwordM. I’m in on the next batch as well.
These springs are so easy to solder that I’m worried I haven’t got them soldered securely enough. I removed the stock double springs from a Sofirn Q8 and put these springs in their place. It was really slow and difficult to remove the old springs. Maybe the springs or the board they were on was soaking up the heat? But when I put the Blue™ Springs on and touched the soldering iron tip to the bottom ring, the springs stuck quickly. Anybody have any idea if that’s normal or if I probably have cold joints?
It’s normal as far as I can tell. I mean think about it. It’s basically copper so it conducts heat like the copper traces. The solder melting is the love flowing from one copper to another
The reason I’m worried is that normally, you have to heat up the copper significantly before the solder will really stick to it. But maybe silver works differently?
@DavidEF, steel is super hard to solder to.
The opposite is true with copper, nickel, silver, and a thick layer of gold: it’s so easy to solder it’s not even funny.
There are 2 reasons for this, and a bonus one:
1. Steel has chromium, and forms a chromium layer that can penetrate a layer of thin gold, which is why something like gold plated steel springs solder poorly, even when gold plated.
2. Steel has poor thermal conductivity compared to nickel, and especially copper and silver. For this reason, the soldering iron can transfer the heat to the solderable area very quickly, making soldering a breeze.
Bonus reason: Nickel and silver don’t form oxides, and even silver tarnish isn’t an oxide that prevents soldering, meaning nickel and silver platings make the soldering even easier.
That’s the reason why soldering pure copper that is oxidized is so hard: copper oxide has very poor thermal conductivity.
I have had very poor results when soldering with pure copper. Tried to make some copper buttons but no luck getting solder to stick to the copper. Tried heating the copper also and it started to turn black. What are the tricks to soldering copper?
