A design that can equal spring bypasses even in the most extreme of cases, that can fit standard flashlight tailcaps, driver side tailcaps, etc.
Even dual BeCu springs hit their limit at extreme currents(23A+), and spring bypasses become worth it if you have the battery and light setup to push past that.
Meaning with a 20700/21700, it becomes viable again to use spring bypasses,
I want to equal spring bypasses in every way possible. That is my goal!
This isn’t my final goal though. I didn’t exactly tell people here that I’m not only looking to make springs for flashlights, and
I’m designing something else too which does use springs, but something that ends up being more… impressive.
Yes, but they were surprised I was doing it for flashlight springs.
What most companies do is just straight up doing multiple baths.
It does end up in thicker platings, but can get extremely expensive, and plating time becomes slower as the layer becomes thicker.
Doing multi-layer differential plating is something that can be used to bypass that, but being more complex and requiring more calculations, apparently, most companies don’t bother doing this, except for very high performance stuff as mentioned before.
Seems like flashlights spring are going on the bleeding edge
Mine arrived! My wife was standing there and tried to confiscate some of them because they are so pretty, saying she could make something out of those. I bought her off with the promise of a new flashlight. (She didn’t know that one of the FW3A’s on my list is for her anyway)
My wife and daughter both agreed they’re very pretty… almost jewelry. But, when I asked my wife if she wanted a couple of them to wear as earrings, she didn’t hesitate to turn down the offer. She’s not really into “unusual” or “interesting” jewelry. Oh well. :laughing:
These springs are so easy to solder that I’m worried I haven’t got them soldered securely enough. I removed the stock double springs from a Sofirn Q8 and put these springs in their place. It was really slow and difficult to remove the old springs. Maybe the springs or the board they were on was soaking up the heat? But when I put the Blue™ Springs on and touched the soldering iron tip to the bottom ring, the springs stuck quickly. Anybody have any idea if that’s normal or if I probably have cold joints?
It’s normal as far as I can tell. I mean think about it. It’s basically copper so it conducts heat like the copper traces. The solder melting is the love flowing from one copper to another
The reason I’m worried is that normally, you have to heat up the copper significantly before the solder will really stick to it. But maybe silver works differently?
The opposite is true with copper, nickel, silver, and a thick layer of gold: it’s so easy to solder it’s not even funny.
There are 2 reasons for this, and a bonus one:
1. Steel has chromium, and forms a chromium layer that can penetrate a layer of thin gold, which is why something like gold plated steel springs solder poorly, even when gold plated.
2. Steel has poor thermal conductivity compared to nickel, and especially copper and silver. For this reason, the soldering iron can transfer the heat to the solderable area very quickly, making soldering a breeze.
Bonus reason: Nickel and silver don’t form oxides, and even silver tarnish isn’t an oxide that prevents soldering, meaning nickel and silver platings make the soldering even easier.
That’s the reason why soldering pure copper that is oxidized is so hard: copper oxide has very poor thermal conductivity.
I have had very poor results when soldering with pure copper. Tried to make some copper buttons but no luck getting solder to stick to the copper. Tried heating the copper also and it started to turn black. What are the tricks to soldering copper?
I’ve found with copper, you need to dump heat into it quickly, or else the copper itself will wick the heat away from the area to be soldered. Also, use plenty of flux. I find it helps too, if you melt a bit of solder onto the tip of your iron, then use the solder itself to transfer heat to the copper, rather than the soldering iron tip. That way, when the copper is ready, the solder will be there, ready to flow.
1. Stick a bit of HCL, or hydrochloric acid/muriatic acid on it. That will destroy the copper oxides, but not the copper underneath.
2. Sand the copper buttons using 200-400 grit sandpaper, then use fine steel wool. Not will it make it very shiny, but also get rid of the remaining copper oxide.
3. Use flux.
4. Use a flat tip soldering iron.
5. Melt a bit of solder on your soldering iron.
Thanks guys. Had some sucess getting solder on the buttons. Now to try and transfer that to a driver is my next task. Really wasn’t that hard. Might have been a lack of patience.
Eh, the driver is the easy part, assuming it’s not totally crowded or something. Pre-coat the pad with a bit of solder, add a drop of flux, place the copper button on top with the soldered side down and heat it up. Since both the driver pad and the copper button will have already been soldered, all you have to do is get them to melt together with a little heat. You should be able to just hold your soldering iron tip to the top of the copper button and let the heat pass through.
Think I figured out my initial issue. The table I work on is aluminum. The button was just laying on the bare table. I think I was having some heat sink issues the first time I tried it. Clamped the button with an alligator clamp and it worked perfect. That’s my guess since it was pretty easy this time. Might keep a small wooden plank around for stuff like this.
