The BIG List of 500m+ Throw Flashlights (In slight disrepair)
Will add the P30, not sure how I missed it.
What’s the C8A or T?
I can only find C8, C8+ which only have like 150m throw.
You did NOT specify stock and/or modded.
TN42
STOCK=XHP35 HI 2000L/700Kcd/1673m ~ $200
Modded[TN42vn 90]= CFT-90-5000L/1.1Mcd/2097m- $600
Modded doesn’t count.
Maybe to you and this list it doesn’t!! Lol!
Stock do not count to me!! Now that Manufactured lights are more like modded lights, the FT03 will be my FIRST STOCK light allowed on the trail! :wink:
EDIT: The TN42 stock still beats many on that list. It would be #8 on the list.
What about the Thrunite TN-42 ???
Sofirn versions. The C8A has more lemons, the C8T is throwier.
Just goggled around quickly, didn’t find anything offhand.
I already mentioned it in Post #12!!
The most common factory C8 around here is probably the Convoy C8 or C8+ with XP-L HI. These have around 500m FL1 throw.
The latest C8+ Throws a lot further than you can spit too…
Chuckle.
Also My Imalent DN35.
Sorry,I didn’t mean to steal your thunder.
Good thing you clarified that, they might have put it on the list twice :frowning:
I think there is wrong with blf gt, the BLF GT is 2500 lumen and throw further than 2000m,
D1S is not available with a shorty tube, so 18650 only.
Great list! I’ll add some of the mfg on your list that I missed! :smiley:
I see that. Don’t know how I was using the Thrunite website but I missed the TN42 & TN40 which both have rechargeable options.
I haven’t included modded lights unfortunately. Too many, not consistently available and the market size just isn’t big enough to justify the time it would take to add them all
I’ll see if I can find them but neither Convoy or Sofirn has them listed on their official websites which is why I didn’t come across them yet.
Will look into this
According to Lumintops official website it’s 2000lm with 2000m throw
Specifications
Emitter: 12V Cree XHP35 High Intensity, mounted on copper DTP MCPCB
Flux: >2000 lm
Intensity: >1 Mcd (ANSI throw >2000 m)
Battery: Four or eight button-top 18650 cells
Driver: 35 W, 2.5 A regulated buck driver with conversion efficiency that exceeds 90%.
Ingress rating: IP65
Weight: Approximately 1.8 kg without cells
Dimensions: 135 mm Ø head x 315 mm length
http://www.lumintop.com/blfgt.html
Thanks, will correct
Thrunite has removed it from their website, but my good old TN32 still would not be out of place here.
No worries!,Fellow PA. resident. I am not perfect either! lol!
I want to sort this list by dollars per mm of head diameter, low to high ;)
Then, I mod.
BAM!
Your top 5 (all the rest are above $1.29):
BRAND MODEL LENGTH HEAD
DIAM
WEIGHT CELL
TYPE
CEL
QTY
EXT
TUBE
EXT
QTY
EMITTER EM
QTY
CRI LUMEN CANDELA THROW MSRP DEAL DIAM $ PER
MM
Sofirn SP70 250mm 90mm 625g 26650 2 XHP70.2 6.25K CW 1 5500 89733 687m $62 $50 90 $0.69
Emisar D1S 127mm 50mm 151g 18650 1 XP-L HI V3 1A CW
XP-L HI V2 3A NW
XP-L HI V2 5D WW
1 1300 130000 715m $40 50 $0.80
Astrolux FT03 170mm 70mm 295g 26650
21700
18650
1
1
1
SST-40-W 6.5K CW
SST-40-W 5K NW
1 2400
2400
190000
190000
875m
875m
$60 70 $0.86
Lumintop GT mini 132mm 50mm 150g 18650 1 18350 1 XP-L HI CW
XP-L HI NW
1 1200
1200
135000
135000
750m
750m
$45 50 $0.90
Sofirn C8T 144mm 45mm 140g 18650 1 XP-L HI 5.5K NW 1 1310 500m $41 45 $0.91
Agreed. But I’ve chosen to start this list without including discontinued Flashlights. If I actually keep it up, in two years like 20% of the list won’t even be available for purchase anymore (other than used). That and I wanted at least as little work as I could manage an 80 item list lol :person_facepalming:
You missed the Lumintop GT70. Or is it on purpose?!
I should’ve remembered… lol BUT in my defense I just double checked and sure enough… Lumintop doesn’t have the GT70 listed on their website! :person_facepalming:
