But not impossible.
HDS is using a wire with a rotating head and a fixed MCPCB for the button, Novatac is using a spring with a rotating head and rotating button.
The end of the tube on the driver side of the HDS is anodized, the trace on the MCPCB is for the end of the wire.
The spring of the novatac is working the same as the inner tube of the FW3A, but with time if the spring wears off, it wonāt be a problem due to its adaptable length.
I think that is the thinnest retaining ring I have ever seen. When I first went to check mine for tightness I didnāt even see it & thoughtā¦ āoh crap, itās glued after allā. :person_facepalming:
But after closer inspection, there it was. Both of mine were tight btw. :+1:
I took some measurements of my 3D version FW3A. I used my Texas_Ace Lumen Tube with a Maukka calibration light. I used a button top 30Q.
Turbo at Turn on saw 3300 lm which went to 2800 lm at 12 seconds then it stepped down. More than I was expecting!
At the 7135 x 1 level I got 132 lm
At the 7135 x 7 + 1 level (top of ramp) I got 1000 lm briefly, but I would say 950-970 lm is about normal and it dropped slowly. At about 30 seconds it was at 800 lm.
Parasitic drain measured an excellent 23 microamps with no sleep delay.
I tried to measure the current draw but I couldnāt get the switch activated with my clamp style and meter. I tried touching an extra wire to the middle tube, but got no response. Any recommendations on how I can measure this?
EDIT: The internal temperature was reading 36Ā°C when it should have been 24Ā°C. I reset it and Turbo lasted 15 seconds before stepdown.
thanks for the data, this is a very interesting light indeed. Is the stepdown after 12 seconds time based or temperature based? 12s seems very quick to heat up? Is it really that hot after a few seconds?
There is no timed stepdown in Anduril (Iām pretty sure). Itās all temperature related and it gets hot quick! Like Toykeeper has been saying, Turbo is really just a short āburstā mode. It does not last long at all.
Damn near exactly what I measured on my T/A Maukka light tubeā¦3360 with 30Q flat top and a VTC5aā¦which is close to the Max for a V2 XP-L HI thru optics and lens, the most I have ever seen was around 1250lms. in reflector lights. I like the 3D (nothing warmer thoughā¦)
The stepdown is temperature based and can be configured for a higher or lower temp range.
Yes, triple emitter FET driven lights this small will get hot FAST. The FW3A has one less emitter than the D4 (so lower wattage) but probably less thermal mass, certainly less in the head of the light.
Yes, and mine is still the factory calibration which could be off a little. Iāll try to see if itās accurate.
With a high capacity 3400+ cell you might see a bit less lumens, but youāll probably gain extra Turbo time. Iāll try out some other cells I have laying around.
I also have all 4 of the Carclo lenses and the stock one seems to be the best, in my opinion. The clear 07 is a tiny bit tighter focused, but I see yellow streaks in the hot spot when shined on a whitewall or equivalent. Eh, itās not worth using in my opinion. The 08 and 09 are nice if you need a wider spot, and donāt need the distance.
The 10511 is called a narrow spot. 22Ā° (lightly frosted)
The 10508 is called a medium spot. 27Ā° (heavier frosted)
The 10509 is called a wide spot. 40Ā° (heaviest frosted)
The 10507 is the non-frosted, clear version with a narrow spot. 18Ā°
Actually, it would not surprise me if the physical dimensions of all four lenses weāre identical and the beam angle difference is strictly due to the amount of frosting on the surface. Here is a picture in the same order as above.
My FW3A is saying itās 38Ā°C, when room temp is about 24Ā°C. Iāll make sure itās fully cooled down internally (when I wake up later) and then check it again. At the moment, my light is probably stepping down a little bit prematurely. Once I reset it, Iāll measure the stepdown time again.
Maukka got 20 seconds out of his light with a 30Q, but he calibrated the ambient temperature as well as bumped the default step down temp of 45Ā°C to a slightly higher 55Ā°C.
