I’m not sure how much interest there would be but i’d definitely get a 12A B4HV.
I imagine the A4 7-9A would be popular. (luxeon V, SST-40)
Why is the difference for the for the 9A version 2A and the 12A version 4A? would it be possible to make a 5-8A version? that’d hit the sweet spot for XPL-HI, Luxeon V , SST-20, SST40, White flat 1 and 2 and others.
Is there any chance to offer Osram CSLPM1.TG (White Flat 2mm²) and CSLNM1.TG (White Flat 1mm²) on a 20mm quad MCPCB? I would be very interested into some DYI light comparable like Acebeam's TK16. Kirill (kiriba-ru) seems to be working on a quad pill for the S11 host.
I have 20mm triple and quad 3030 on my "wish-to-do" list for a while, regular 3535 pcbs are just not good for that, even on single LED pcbs white flat slides to one side 50% of time during reflow.
One more qiestion: is there a difference between direct drive LD-A4 4-6 amp version versus DD on 7-9 amp version of the same driver? Is the FET the same?
What happens if for example I use battery that can give 5 amp max and I set it to 6 amps regulated?
Thanks!
Also I added "Do not solder FET+NTC+connector" option for big (32mm and 34mm) mosX boards - for those who want to use those boards with any other driver except LD-B4.
Those firmwares are made for DD drivers and are not compatible in any way with my drivers, and vice versa. Future compatibility is also not possible, drivers which use them don't have (IHMO) basic hardware requirements like current regulation and external temp. sensor support.
