Holy crap TK! YOU’RE AWESOME!
First off, thanks for the insight on double click turbo from off. I’ll admit this is a bit like sorcery to me, so it’s gonna take me a few re-reads to parse out and fully understand what you’re talking about.
Secondly, I finally got around to flashing my FW3A last night. I wanted fancy moon lockout mode. Before I built the hex I thought… I should probably merge the latest fsm just in case. And then when I went to enable fancy moon I seen it was already enabled by default! Took me by surprise, I had to make sure I didn’t mix up my files. I figured you had enabled it by default now, which is pretty cool.
But then this morning, I just read your change log here, and DANG! I was literally sitting on my couch with my FW3A, giggling as I tried every new feature that I didn’t even realize I flashed last night haha.
You’re the best, and your changes to the code have solved many problems. Most recently one friend had been bothered by the thermal regulation on his D4, does this solve that thermal problem as well? Or alleviate it? I suppose I’ll flash it to test it for you best I can as well.
Also another friend had been confused by the ramp in strobe modes, but now that is much more intuitive, thanks!
Of course momentary strobes seem fun, and candle and lightning mode are already awesome, but it’s nice to see them receiving tweaks.
I don’t have much use for the button mode timing options and such, I’ll just trust your opinion on the defaults, but I’m glad the option is there.
Anywho, I guess I’m one of the first to test your newest revision haha. I’ll let you know if I find any trouble!
Sorry if this is a bit too flattering, but honestly, thank you for your hard work. You rock!
Edit: ah, it seems I merged before your final revision. I don’t have the use_Manual_memory enabled apparently. Well I guess I know what’s next, I’ll be reflashing this FW3A lol
